ATARI 2600 6 switch WANG CAPACITOR
  • BigTroll
    • Sep 2010
    • 1317
    • LAMBDA SOND
    my 4 switch atari had kinda died so i found a used 6 switch and brought it back to life, when i got it, it had no power or video. so far recapped the main 2200uf cap and two small 4.7uf caps, the main was a WANG brand and was replaced with Nichicon and the smallers were also WANG (=====> replaced with ITT which is a brand i have not heard of. Also replaced the power switch with one from my doner 4 switch board and resolded some joints, the ribbon cable between the mainboard and the switch board was problem matic so sand papered the metal prongs and she seems good to go now, working great.
    My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: ATARI 2600 6 switch WANG CAPACITOR
    Nice!
    wang dang sweet poontang!
    I think I might have an "ITT" capacitor or two in my cap box. Not sure of the reliability of them, never used them on anything yet. They are just general purpose if I recall correctly.
    Muh-soggy-knee
      master hoarder
      • May 2008
      • 12170
      • Bulgaria
      Nice fix. It's interesting to see that crappy caps were used even in very old electronics.
      My guess is they have nothing to do with ITT Tech University
      • lti
        • May 2011
        • 2547
        Wang, pay attention!
        "I was distracted by that enormous flying..."
        The best cap brand I've found was FU-YU.
        The leads on that Nichicon cap look unusually thin.
        I have seen ITT caps in really old stuff.
        • BigTroll
          • Sep 2010
          • 1317
          • LAMBDA SOND
          Yikes i hope they are real, I haven't seen to many nichicon axials so its hard to say, either way the WANGs were leaking so I wanted to be proactive, also I plan on replacing the teapos in my other 4 switch, the primary isn't leaking but the tiny 4.7uf 35v caps are showing signs of leakage and the video quality is not nearly as good as my 6 switch.
          • SteveNielsen
            Retired Tech
            • 2327
            Nice save. I used to have such things. I was sad when having to part with them. At one time I had two working Commodore C-64s. Sigh.
              • 31007
              i have an amiga1200
              • japlytic
                • Oct 2005
                • 2086
                Could these Taiwanese electrolytics be first or second generation units?
                  Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                  This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                  09-06-2024, 05:30 AM
                • Natob82
                  Micro Momentary Push Switch?
                  by Natob82
                  Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                  12-21-2022, 05:22 AM
                • grimacelord
                  NEC TurboExpress On/Off Power Switch Replacement Help
                  by grimacelord
                  I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                  I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                  I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                  11-09-2023, 09:49 AM
                • SluggerB
                  Help making a switch work the opposite way with a relay
                  by SluggerB
                  I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                  I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                  It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                  02-07-2025, 07:57 PM
                • Prolog
                  RTX 3080 FE Identifying capacitor
                  by Prolog
                  Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                  I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                  I hope these photos make it clear which component I am referring to:
                  (yes, the soldering is a bit botched from removing the blown one, I know)
                  I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                  12-01-2024, 08:27 PM
