Xbox 360 S Failed RGH3 Repair
  • cstout
    • Jan 2024
    • 24
    Hello all,
    I've just had my first ever run in with a mod failure. Really bummed about it, but hoping to learn more from it. It started as a means for soldering practice and ended with me wondering if it could be restored to function or if something were shorted and now dead.
    This is an Xbox 360 S and the board sticker reads: X865009-001 Rev. D. It's a CORONA V4 (4GB nand, samsung ram).
    When I apply power and press the power button, there is no fan movement or lights and all I get is the power-on beep. If I press the eject button I get the different eject sound beep but still, no fan movement and no lights at all. The power supply has been tested good and prior to the RGH3 mod attempt, this bad boy booted right up and worked great. 😅
    I'm really not sure where to start on this one, especially since I don't have any light codes to track down a specific failure.
    Any help is greatly appreciated. This one's been bugging me to figure it out.
  • cstout
    • Jan 2024
    • 24
    Here are some things I've checked so far:
    • R4D3-R4D8 resistors all check out
    • No bent pins in any USB ports
    • No visible damage to wireless module/power button board
    • cstout
      • Jan 2024
      • 24
      Edit: Also, all soldered wires have been removed. Back to stock.
        • 31298
        start with what you know - the fans, follow the power and ground back to whatever fet or transistor is switching them.
        then see if you have 12v still
        • TMTGTR
          An Xbox One PSU Odyssey
          by TMTGTR
          Firstly I am not a tech. You guys may see mistakes or oversights in my methods so don't be bashful and feel free to post corrections/opinions.
          =>Background:
          I bought my son a used Xbox One original model: A12-220N1A Rev: 02 with original PSU & 2 controllers 7 years ago. I “modded” the unit placing a 4.5” 12V exhaust fan with a 9v wall wart adapter on top of the vent/fan of the unit. And plugged the Xbox PSU into a Tripplite LTR-600 voltage regulator. Also connected to the Tripplite are a 275w computer tower, an Xbox 360 PSU and a Westinghouse 52” LED TV. ...
          06-17-2022, 05:40 PM
        • Themi
          xbox one x fast beep on / off
          by Themi
          got given an xbox one x as dead, no pressure to fix as has been replaced and owner doesn't want it back
          symtoms: press power button, white light, beep on and off almost immediately
          checks:
          • dead short on MEMIO test pad (doubt this is good but I don't have another board to compare against) injected voltage 1v nothing showing on thermal
          • checked under thermal during power on only slight heat in SB, everything else front and back of board cold
          • no shorts on any other test pads MEMPHY etc
          • has standby 1.1v, 1.8v, 3.3v, 5v
          • psu good has 12v
          • no 12v rail short
          • no short
          05-28-2024, 07:42 AM
        • ahmedtou
          HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
          by ahmedtou
          help me please
          I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
          When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
          I will share all the details with you, including the disc information.
          Code:
          HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
          Current Profile: BD-R
          Disc Information:
          Status: Empty
          State of Last Session: Empty
          Erasable: No
          Free Sectors: 12,219,392
          Free Space: 25,025,314,816 bytes
          Free Time: 2715:27:17 (MM:SS:FF)
          Next
          08-27-2025, 08:49 AM
          HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
          This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
          09-12-2024, 02:00 PM
        • Stevedb
          Boardview xbox 360 , xbox fat , xbox one x and xbox one s
          by Stevedb
          Hi all
          I will share the boardviews i found internet from the xbox 360 , xbox fat and xbox one x and xbox one s
          Pasw netcomchetumal.
          Enjoy it.
          Greetings Steve
          From Belgium...
          04-04-2023, 12:42 AM
