xbox one x fast beep on / off
  • Themi
    • May 2020
    • 79
    • Scotland
    got given an xbox one x as dead, no pressure to fix as has been replaced and owner doesn't want it back
    symtoms: press power button, white light, beep on and off almost immediately
    checks:
    • dead short on MEMIO test pad (doubt this is good but I don't have another board to compare against) injected voltage 1v nothing showing on thermal
    • checked under thermal during power on only slight heat in SB, everything else front and back of board cold
    • no shorts on any other test pads MEMPHY etc
    • has standby 1.1v, 1.8v, 3.3v, 5v
    • psu good has 12v
    • no 12v rail short
    • no short on 1.1v, 1.8v, 3.3v, 5v
    • test shorted EN to 3.3 VIN on LDO voltage regulators and get 1.1v and 1.8v
    • no short at retimer or encoder
    • no short at ethernet
    • ports in good condition
    • no damage / burns / holes to board components
    board was tested bare no attached components (drives, etc) only power button board
    tested from bench psu
    I am guessing APU, SB or SB nand ?
    any ideas? I don't know what else I can do to proceed further
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • duwane
    MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
    by duwane
    Hi All.
    I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
    Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
    After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
    Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to...
    10-17-2023, 07:48 PM
  • sfernandes
    Sega Dreamcast NTSC-U Revision 0 Launch Unit GD ROM PCB Board Short
    by sfernandes
    Symptom: When I press the power button the power LED lights up for a second and the fan etc spins for a second then the unit turns itself off and will not do the same thing again unless I unplug the power cable for a few minutes then plug it back in otherwise if I just turn the power switch off and back on right after it comes on for a second it will not come on again unless like I said unplug the power cord for a few minutes then plug it back in.
    What I have done to try to isolate the issue so far:
    The system powers on and stays on with...
    01-23-2023, 06:03 PM
  • survivalbloke
    Need help pinpointing my short on this board (Lenovo) NM-D351
    by survivalbloke
    This is a Lenovo Thinkpad P15s Gen 2 with a board NM-D351. I'm having trouble finding my dead short to ground. I have the area narrowed down after much probing. You'll see in the boardview, there are two coils involved. I removed those coils and verified that that short is not on the mosfet side of those coils. . You'll see an arrangement on both sides of the board of 5 caps and one smaller one to the side. I have removed ALL 12 of these small caps and still have the short. Prior to that I injected at those caps with 1v5a and the short was only drawing 800ma so I could not see anything on thermal....
    03-23-2024, 11:24 AM
