PS5 stuck at restore and than no power for some time
  • groomit
    • May 2023
    • 29
    Hi there,
    Tried to condense the problem in the title. Hope it was appealing for someone.
    I bought a broken PS5 with 2 sek. BLOD. When it arrived I noticed the bad condition of the console housing, bent cooler pipes and deformed disk drive. Yeah , obviously very bad drop damage. And obviously not appropriately described in the offer. Because it was my first hand on a PS5 for an okayish price, I decided to take the risk.
    It is an EDM-020 CFI-1116A.
    First thing I noticed was wrong initialization amperage. It went to 450 mA an then dropped to around 150 mA. Figured it was the WiFi chip, that was kind of shorted. After replacing it, amps were correct (300 to 9). But still 2 sec blod.
    Second thing I found was a non initializing RAM chip. I figured this using a thermal cam on boot. Reflowing wasn't successful but reballing did the trick.
    Finally the console booted into safe mode. When trying to restore the console I got an error translating to disk drive not recognized.
    So I disassembled this as well. No obvious damage. But hooks on the data cable from MB were quite worn. So first I resoldered some suspicious connector pins on the BD PCB and then carefully aligned the data cable.
    Now I'm at the stage were the console boots into safe mode. When trying to restore the FW, it stops at "1 sec remaining" on download. It doesn't react to controller input or power button presses at this stage. Kind of stuck. When I try to hard reset by pulling the AC-cable, the console appears to be completely dead. No beep, no light. After some time.it again boots into safe mode, stuck at the same time on restoring and than ... Dead. Reproducible behavior.
    So this brings me to your immense knowledge. I highly suspect a bad solder joint on the south bridge, which looses contact when the board is at a certain temperature. Do you support this assumption or do you have a different suggestion?
    Would love to see this device come alive again :-).
  • Mommotexx
    • Mar 2018
    • 10
    • Norway
    Would probably suspect SSD or SSD controller, but hard to say.
    There are ways to read the Southbridge error codes, haven't done it myself yet, but there are some videos about it, and TheCod3r have a website where you can search for the UART codes, maybe your problem has been diagnosed there.
    Could also be bad solder joints under the APU, as you also had bad solder joint under one of the ram chip.
    • groomit
      • May 2023
      • 29
      Thanks for your suggestion. In the meantime I reballed the South bridge. Now the console is stuck at a pulsing blue light.
      I read the error codes from the uart interface:
      80000140: APU Freeze (No Response) - GDDR6 Data Line Issue (Replace)
      So either RAM or APU. Applying pressure to each IC and APU during boot did not solve the issue. Judging by thermal cam all RAM ICs are heating equally.
      So how to find the culprit? Don't have spares at hand. :-/
      Think I'll have to reball all of them.
      • TheWizard
        • Feb 2015
        • 190
        Groomit,
        Were you able to resolve this? I had the same symptoms and upon using thermal camera. RAM module 6 was not lighting up. I reballed but no change. Replaced with NEW known good module but no change. UART shows the same error code "80000140: APU Freeze (No Response) - GDDR6 Data Line Issue (Replace)
        Just wanted to see if you got any futher? Thank you.
        • groomit
          • May 2023
          • 29
          Unfortunately not. After reballing every ram IC and finally the apu I get a different Error regarding a short somewhere. Need to investigate this. Hopefully I don't have to reball the apu again :-D
          • TheWizard
            • Feb 2015
            • 190
            Please keep me posted. I don't have a BGA Rework station to reball and reseat the APU so I didn't go that far. But our issues we are having seem to be the same. I would be curious where you land this one. Good luck!
            • Stunt
              Hp Laptop Stuck on Hp protected by hp sure start screen
              by Stunt
              Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
              I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
              I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
              Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
              screen that's it and stuck there. I left it until the following day and i still...
              09-02-2025, 01:51 PM
            • stormanimal83
              Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
              by stormanimal83
              Hey....
              Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
              my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
              01-18-2024, 02:15 PM
            • Flasman90
              Macbook Pro DFU Restore Issues
              by Flasman90
              I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
              - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
              - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
              08-30-2025, 10:27 AM
            • gabri2211
              Xbox Series X Console Won't Turn On - Broken Nexus Connector on Mainboard
              by gabri2211
              Inside the console there is a small circuit board (see photo) that contains the main power switch, the one on the front.
              This circuit board connects to a 10-pin flat cable called NEXUS that terminates on the motherboard.
              This NEXUS connector broke.
              Can anyone tell me, while waiting for a replacement, if it's possible to turn on the Xbox by disconnecting this circuit board and making some modifications (like adding a small power button) on the motherboard?
              The Xbox has a power supply that provides 12 volts on all outputs, so the power...
              07-28-2025, 07:13 PM
            • ekozeko333
              by ekozeko333
              🧠 What I’ve Done So Far
              Flashed...
              06-21-2025, 02:48 AM
