Sega Genesis 1 - No mono audio output
  • caphair
    • Nov 2011
    • 1249
    Not sure if anyone will be able to help me with this, found my old sega genesis and hooked it up, video is fine but I have no audio out from either the RF or SCART connectors but the front headphone jack works.
    I found a schematic but I'm not too familiar with how audio works, it looks like the mono output goes through a LM358, could this be bad?
    The attached image doesn't zoom, here's a direct link to it:
    http://cgfm2.emuviews.com/img/mega3.gif
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Sega Genesis 1 - No mono audio output
    First thing I would check is the switch in the headphone jack. This can go bad sometimes and cause issues like this. The switch contacts get oxidised and don't make connection very well.
    Is it possible that you could get that schematic picture in a higher resolution? Because it is hard - no, impossible to read the part numbers and values
    Muh-soggy-knee
    • caphair
      • Nov 2011
      • 1249
      I posted a direct link to it which is much clearer/bigger.
      here it is again:
      How would I clean the switch? Can I just spray something in or does it need to be taken apart? Thanks
      • caphair
        • Nov 2011
        • 1249
        Looking at the schematic, it doesn't look like the headphone jack has a switch, looks like there are two sound chips. One for stereo going to headphone and another going to mono.
        I could be wrong?
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Yeah, my apologies.
          There doesn't appear to be a switch in the headphones jack.
          Well, yes, the LM358 could be bad, or the chip IC13 could be bad.
          You probably could try connecting an audio amplifier and speaker to the output of the LM358, and see if you can get any sound. If you can, then I'd suspect IC13 is bad. However, perhaps the LM358 may be passing audio, but not enough for IC13. Check the feedback resistor in the LM358 amp circuit and make sure it is ok.
          Muh-soggy-knee
          • caphair
            • Nov 2011
            • 1249
            Originally posted by ben7
            Yeah, my apologies.
            Are you referring to R74 33K? It reads 32K
            I'm not exactly sure how I could connect an amp and speaker to it's output. Any voltage readings I could try?
            Also I looked up the LM358 and it's a two stage op amp, looks like only one stage is being used, could I try connecting inputs to it's second stage to see if I get audio?
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              inject at c30.bet its open.had a few in here for that.
              • caphair
                • Nov 2011
                • 1249
                Already tried swapping that cap and still no audio, though I only had on hand a 10uf 25v one and original is 10uf 50v. Not sure if that matters? It was for a quick test
                • caphair
                  • Nov 2011
                  • 1249
                  Can someone help me understand how this circuit works, are LM358 and IC12 both amplifiers for the sound coming from IC11?
                  If so, why does the output of LM358 go into IC13 rather than just straight out to RF/SCART outputs?
                  • lti
                    • May 2011
                    • 2558
                    Yes, they are both amplifiers. IC12 is the headphone amplifier, and the LM358 produces an amplified mono signal. The datasheet for IC13 (CXA1145) says that it only has a buffer inside for the audio section, so it should pass the input signal directly through without altering it.
                    C31 could be bad as well.
                    • ohmmy
                      • 182
                      Awesome. Thanks. By buffer what does that mean exactly? Also anyway I can pinpoint where audio is lost with just a multimeter?
                      C31 looks like it's only before the SCART connection which also doesn't produce audio.
                      Could I run some wires from output of LM358 to the audio pin of RF module bypassing IC13 to see if I get audio out?
                        IC13 CXA1145 spec:
                        http://pdf1.alldatasheet.com/datashe.../CXA1145P.html
                        http://console5.com/wiki/CXA1145
                        The LM358 is probably does not have enough power to drive the modulator module and the SCART so the output of the LM358 is fed into the buffer amp inside the IC13. LM358 is used as a mixer for Left and Right signals.
                        • ohmmy
                          • 182
                          Originally posted by budm
                          IC13 CXA1145 spec:
                          Cool I get it now. So I couldn't simply try to bypass ic13 to see if I get sound and determine it's the problem?
                            You can lift C30 positive leg off the board, C31 positive leg off the board, then tie those two positive legs of those 2 caps together and see if you will get sound on the SCART.
                            • ohmmy
                              • 182
                              By doing that will it boost the sound from LM358 enough to output sound?
                                We just want to verify that LM358 is putting out audio or if it is dead, you should hear the sound, if not, then LM358 is bad not the buffer amp problem in the IC13. Doing as I indicated above will bypass the IC13 to see where the problem is.
                                • ohmmy
                                  • 182
                                  Ok I'm just trying to learn as I go along. In this case what would tying those two caps do as oppose to just going straight from LM538's output to SCART?
                                  I'll try it regardless just curious.
                                    I have you lift the leg for easy way to try out, If it is SMD cap, then that will be problem, we just need to take the output of the LM358 and feed it to coupling cap and to not allow the DC at the output of the LM358 feeding into the receiving circuit, at the same time we must disconnect the input and output of IC13 from being connected to the circuit. The output pin of IC 13 has very low impedance so you cannot leave it connected so if you just jump the output of the LM358 to the SCART, the output of IC13 will load down the circuit.
                                    • ohmmy
                                      • 182
                                      Ok, tied them two caps together and still no audio from SCART.
                                      So I can conclude the LM358 is defective?
                                        Sounds like it if you do not even hear anything at all. Another test is to check the DC voltage at the output pin of the LM358, it should be around 1/2 of the Vcc power supply voltage.
                                        • kotel studios
                                          Lantec PULSE 386 subwoofer - no audio output
                                          by kotel studios
                                          Hi
                                          I have this Lantec PULSE 386 subwoofer I got a while back laying around awating repair for quite some time. Sadly it's missing it's original speakers which it came with.
                                          After plugging in the mains, the LED on the volume controller lights up. When I plug in the 3.5" jack cable to my soundcard (confirmed to work), I get no audio on the subwoofer (nor the speaker jack at the back).
                                          The PCB is quite simple. There is a UTC4558 amp and two D6282 audio amps. When I put my finger on the UTC4558 I can see and hear the speaker "fart". Although, the left...
                                          Yesterday, 04:15 AM
                                        • samson7point1@yahoo.com
                                          Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                                          by samson7point1@yahoo.com
                                          The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                                          The player processes the audio signal using two different reference frequencies. The "R"...
                                          04-30-2024, 11:22 AM
                                        • mecha1166
                                          Copper corrosion? Yamaha HS8S Audio 1 output only
                                          by mecha1166
                                          OAUD Yamaha HS8S Audio one output only.
                                          I have pulled the output board. Output txsistors are ok (only 2 main output). Everything measures the same on each side. Customer did not bring in speakers so I cannot go too deep. I did notice a greenish tint on the tip of the solder joints that connect to the COPPER output connectors. All 6 have a greenish tint at the tip - each side has 3 pins each. Anyone else have copper speaker output pins that corrode at the place on the PCB where they are soldered? I will try to add a photo. Thanks.
                                          08-04-2023, 02:55 PM
                                        • dicky96
                                          Denon AVR-X500 No audio output
                                          by dicky96
                                          Hi guys, I have this AVR-X500. It has no audio output but if I select some input (DVD) and connect an audio signal to the RCA DVD inputs, I hear a relay click and sometimes there is a slight crackling on the speakers.
                                          I only have 2x 8ohm speakers attached to Left and Right front.
                                          If I plug headphones in, the crackling noise stops but I get no audio on the headphones.
                                          I checked the voltages marked on the connectors on the Preamp PCB (12V, 5V etc) and they are all present. There is also plus/minus 56V on the bridge rectifier on the main amplifier PCB...
                                          02-22-2022, 08:36 AM
                                        • FrancescoV
                                          Onkyo HT-R390 no sound output, video output ok
                                          by FrancescoV
                                          Good morning everyone,
                                          I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                          The firmware reported is the following:
                                          M:1.00/11107BLP
                                          D:?.??/????????
                                          O:1.00/11107AL
                                          The DSP firmware given the question marks seems corrupt.
                                          On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                          05-11-2025, 02:59 AM
