Sega Genesis 1 - No mono audio output
  • ohmmy
    • 182
    Re: Sega Genesis 1 - No mono audio output
    Ok I was able to get a 358 off a friend yesterday so I didn't have to wait for the one I ordered.
    Put it in, everything worked great for about two hours total of game play through out the day, then no audio again.
    I decided to start from the basics again and now I do get sound from the SCART connector. So I'm assuming the rf modulator is bad now?
    Is there anyway to repair this or somehow run audio right to the rf port bypassing all the circuitry in it? Can't seem to find a replacement anywhere
    • samson7point1@yahoo.com
      Help troubleshooting an audio problem with an RCA SGT-250 CED Player
      by samson7point1@yahoo.com
      The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
      The player processes the audio signal using two different reference frequencies. The "R"...
      04-30-2024, 11:22 AM
    • mecha1166
      Copper corrosion? Yamaha HS8S Audio 1 output only
      by mecha1166
      OAUD Yamaha HS8S Audio one output only.
      I have pulled the output board. Output txsistors are ok (only 2 main output). Everything measures the same on each side. Customer did not bring in speakers so I cannot go too deep. I did notice a greenish tint on the tip of the solder joints that connect to the COPPER output connectors. All 6 have a greenish tint at the tip - each side has 3 pins each. Anyone else have copper speaker output pins that corrode at the place on the PCB where they are soldered? I will try to add a photo. Thanks.
      08-04-2023, 02:55 PM
    • dicky96
      Denon AVR-X500 No audio output
      by dicky96
      Hi guys, I have this AVR-X500. It has no audio output but if I select some input (DVD) and connect an audio signal to the RCA DVD inputs, I hear a relay click and sometimes there is a slight crackling on the speakers.
      I only have 2x 8ohm speakers attached to Left and Right front.
      If I plug headphones in, the crackling noise stops but I get no audio on the headphones.
      I checked the voltages marked on the connectors on the Preamp PCB (12V, 5V etc) and they are all present. There is also plus/minus 56V on the bridge rectifier on the main amplifier PCB...
      02-22-2022, 08:36 AM
    • FrancescoV
      Onkyo HT-R390 no sound output, video output ok
      by FrancescoV
      Good morning everyone,
      I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
      The firmware reported is the following:
      M:1.00/11107BLP
      D:?.??/????????
      O:1.00/11107AL
      The DSP firmware given the question marks seems corrupt.
      On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
      05-11-2025, 02:59 AM
    • classicandy
      HP Pavilion 15-N DIS to UMA Conversion done BUT no Audio output
      by classicandy
      Hi All,
      Please, I need help in getting my audio output to work. I did a conversion from DIS to UMA in HP Pavilion 15-N AMD (Model: U92) BUT I'm not getting any sound. I think the audio is tied to the faulty graphics chip. Is there any way i can convert the audio too?
      [MOD EDIT]
      Link to Quanta U92 Schematic - https://www.badcaps.net/forum/troubl...hematic-needed
      08-09-2022, 12:43 AM
