Xbox 360 with blown caps
  • synapse
    • 51
    Been given an Xbox 360 to fix that has blown caps (the big ones near the gpu/cpu heatsinks).
    THERE ARE:
    14 Rubycon 6.3v 820nf mfz 105deg 8mm dia
    9 Rubicon 16v 1500uf mcz 105deg 10mm dia
    Done a bit of reading here and the suggestions have been to replace with Rubycon MCZ, Nichicon HZ or HN but i'm buggered if I can find any.
    then I came across this thread:
    https://www.badcaps.net/forum/showthread.php?t=21540
    https://www.badcaps.net/forum/showthread.php?t=13542
    The local electronics store have a really bad range and crap "suntan" brand.
    I'm in Australia so the only options as far as im aware are:
    http://australia.rs-online.com/web/
    http://au.element14.com/ (free delivery for online orders in December)
    So over to the professionals......what is my next best alternative? I know I could order from here, but postage from the US takes a while.
    Ashley.
    I'm currently a Part-time Computer Systems Engineering student.
    Full time Service Assurance (faults) for a large Telco.
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Xbox 360 with blown caps
    Suntan may not be good so I don't suggest you use them.
    You can safely replace the 6.3v 820uf Rubycon MFZ caps with any of the following polymers:
    2.5V 820uF Sanyo SEPC,
    2.5V 820uF United Chemicon PSC,
    2.5V 820uF Nichicon FPCAP R5 and E5 series
    These will also likely work: 2.5V 820uF Nichicon FPCAP R7 series and 2.5V 820uF Fujitsu FPCAP RE series.
    As for the Rubicon 16v 1500uf MCZ, you can use:
    Rubycon MCZ (obviously ), Nichicon HN, Panasonic FL (you won't find them for sale anywhere but if you do find them on a motherboard, they will work), and Sanyo WG. <--- all of these should be the same 16V, 1500uF rating.
    I'm not sure if the Xbox 360 can take polymers in place of those 16v 1500uf caps, but it probably will. If you feel experimental, use 16V 330uF or (preferably) 470uF polymers. United Chemicon PSC, Fujitsu FPCAP RE series, and Nichicon FPCAP R7 series are among some of the choices.
    • synapse
      • 51
      Thanks Momaka.
      Definitely not touching suntan, some nasty stories are online.
      I had already decided to go for Polymers to replace the MFZ's (with Nichicon R7)
      I'll take your advice and use Nichicon HN for the others. Not feeling too experimental.
      Now I have a question that comes from your poly recommendations if I were to get experimental. How come you suggest using such low capacity here (1500uf vs 330/470) but for the 820's you suggested the full 820? I have read a bit on here that people suggest using around half the capacity when switching to poly due to the faster discharge rate of these.
      • mariushm
        • May 2011
        • 3799
        The capacitors are connected in parallel so that the ESR is reduced to a very low value.
        Electrolytic capacitors have an ESR that varies with the size and capacity value of the capacitor.. bigger capacitors usually have lower ESR.
        For example, that 1500uF 6.3v MCZ may have 0.08 ohm esr while a 470uF 6.3v electrolytic may have 0.15 ohm.
        The xbox doesn't need 1500uF capacitors, it may only need 470uF per capacitor, but it's just that value that was the best compromise between big enough capacitor size and low enough esr for each invidual capacitor. Then the designer goes even further by putting several in parallel to reduce the ESR to an even lower value.
        Polymer capacitors have much lower ESR from the start - even a 330-470uF 4v polymer capacitor can have less than 0.01 ohm esr. For example, a Nichicon LE 560uF 5v capacitor has 0.005 ohm (5 milliohm esr) :
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          It's just based on what I have seen in computer motherboards and other Xbox 360s.
          IIRC, the newest board version of the Xbox 360 (not the slim one, though) comes with 2.5V 820uF Sanyo SEPC and/or Chemicon PSC polymer caps in place of those 6.3V 820 uF Rubycon MFZ and Nichicon HNs, so that's how I know those will work for sure.
          As for the 330/470... many computer motherboards will have 3 to 5 of these on the CPU VRM high side. The Xbox 360 slim also uses (IIRC) 4x 16V 470uF polymers for the CPU/GPU VRM high side. Based on that, I think the old Xbox 360 will work fine too. The VRM circuit for both are similar, as are all CPU/GPU VRM circuits in general (and by VRM, I actually mean a buck circuit). In many cases, this is actually why the half-capacitance "rule" works. And I say "rule" because it is actually more of a general guideline than a rule. You can often go higher or lower in capacitance without ill effects, of course all depending on how many caps there are in the buck circuit.
          • synapse
            • 51
            Got it,thats really helpful.
            Thanks guys.
            • synapse
              • 51
              The caps are on the way.
              I'll update with pictures and results as I go along.
              Also planing to make a few tweaks to the cooling to prevent anything like this happening again.
              • synapse
                • 51
                About to start removing these....
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  You'll need a tough iron for them. 50W or more preferable (or else you'll need to preheat the board well). Make sure to put lots of solder on the tip of the iron and also add some flux to the pins of each cap. This will greatly help with the heat transfer. I've tried many different methods to remove caps from these boards (hot air only, hot air + iron, preheat + iron, Hakko 808 desoldering gun) - none of which worked too well (the Hakko 808 was okay when used as an iron). The best and easiest method really is just with a temperature controlled soldering station with a chisel tip and lots of solder on the tip and fluxed pins on each cap. It's not required to have a soldering station (you can do it with a regular iron too), but it definitely makes the task easier.
                  • synapse
                    • 51
                    Yeah thanks thats what I used, Hakko 936 clone at about 420 deg C. some flux and solder to create a larger heat bridge to the board and the leads. Then just ease out one leg at a time.
                    They are all out now.
                    One thing strange i noticed was a few of the leads were loose in the board. Either a bad solder job from the factory or perhaps the joint had become hot and brittle when this thing overheated at some stage.
                    I should get time to put in the new caps later this week.
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      somebody do an oven reflow with the caps still on the board?
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        ^ Most likely. I've never seen Xbox 360 caps fail on their own or due to clogged fans. It takes a LOT of heat to make them bulge. Hope the small caps didn't die.
                        • synapse
                          • 51
                          Maybe a Towel trick? this thing still had the warranty sticker intact before I cracked it open.
                          • Krankshaft
                            • Jan 2007
                            • 2328
                            These old units are timebombs waiting to happen the GPU is way too inefficient produces too much heat and the constant thermal cycling cracks the BGA balls connecting it to the board. Heat is also another contributing factor as insufficient air flow due to clogged heatsink fins (that you can't clean thanks to Microshaft's warranty sticker) hastens the boards demise.
                            The newer slim 360s have the CPU and GPU on one die and run way cooler. They also finally put a heat spreader over the dies.
                            You can see the comparisons here:
                            If the GPU balls are cracked neither the towel trick, bake it like a batch of brownies, or the board warping and destroying X clamp hack will produce any lasting results. You'll need to either reball or reflow.
                            That looks like an early generation console as well since the GPU heat sink was later updated to include a heat pipe coming out of it which would then terminate on some radiator style cooling fins.
                            The earlier consoles were known for popping caps (but I believe they were a bad batch of Nichicons) replace them and give it a try but don't get your hopes up if it still doesn't work.
                            • synapse
                              • 51
                              Just Had the chance to pop these in.
                              I'll test it out tonight.
                              • synapse
                                • 51
                                ......and she lives!
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  • Bulgaria
                                  Congrats!
                                  Now you won't have to worry about the caps popping again
                                  • synapse
                                    • 51
                                    Thanks!
                                    Also made a few cooling mods while I was at it if anyone is interested.
                                    The plastic will help the air to be drawn through the heatsink fins better. Also re-purposed an old P3 CPU fan after giving it bit of a trim and tapping into 12v source just under the main power connector. It sits on top of the extra GPU heatsink on the heatpipe. It also helps to draw in some cool air from the small air vent in that part of the case.
                                    So far so good!
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      • Bulgaria
                                      Good.
                                      These Xbox 360s do need some fan mods to help them stay cool. Most of the time, I just modify the fans to run on 9 to 10 V constantly. It makes the Xbox louder, but at least it stays cool.
                                      • dj_ricoh
                                        • 2073
                                        i`m 100% sure that the motherboard from that xbox has seen the inside of the oven :P
                                        you can see the color of the solder going from orange to brown (:
                                        • OriginalDaggers
                                          XBox 360 All Polymer Capacitors
                                          by OriginalDaggers
                                          As the title says, Xbox 360 Polymer Capacitors, replacing all on a Kronos 1 revision board.
                                          I went over a thread here (Xbox 360 with blown caps) and gather some extremely useful knowledge!
                                          If I have things right, I can replace them TO
                                          x9 : 1500uF 16V 10x20mm
                                          TO: 470uF Nichicon FPCAP R7
                                          x2 : 820uF 6.3V 8x12mm
                                          TO: 2.5V 820uF Nichicon FPCAP R5
                                          On this revision, there are other 820uF polymer capacitors for GPU/CPU - I'll be replacing those anyway with the above FPCAP R5
                                          What's a good replacement for the smaller...
                                          This can be anything from game consoles to arcade games to anything else that doesn't really fit into any of the above categories. When starting a new thread, please put the make AND model of your device in the thread title. Also be VERY descriptive of your issue, that way you'll get the best answer possible!
                                          02-20-2024, 12:49 PM
                                        • TMTGTR
                                          An Xbox One PSU Odyssey
                                          by TMTGTR
                                          Firstly I am not a tech. You guys may see mistakes or oversights in my methods so don't be bashful and feel free to post corrections/opinions.
                                          =>Background:
                                          I bought my son a used Xbox One original model: A12-220N1A Rev: 02 with original PSU & 2 controllers 7 years ago. I “modded” the unit placing a 4.5” 12V exhaust fan with a 9v wall wart adapter on top of the vent/fan of the unit. And plugged the Xbox PSU into a Tripplite LTR-600 voltage regulator. Also connected to the Tripplite are a 275w computer tower, an Xbox 360 PSU and a Westinghouse 52” LED TV. ...
                                          06-17-2022, 05:40 PM
                                        • burom
                                          Xbox 360 Xenon Modern Capacitor Replacements
                                          by burom
                                          I found my old Xbox 360 in storage and opened it up to see if there was anything that broke since it was built in 2006 (launch era Xenon revision, never red ringed, never been serviced) and didn't want to find out by releasing magic smoke. Upon moving the dust bunnies out of the way I was greeted by a bunch of capacitors with crud coming out of the top; it doesn't seem to have leaked onto the board so at least I have that going for me.
                                          I'm posting here because I want to try to source replacement caps myself from Mouser or Digikey instead of braving eBay or waiting for places to have...
                                          06-07-2024, 05:10 PM
                                          HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                          09-12-2024, 02:00 PM
                                        • DrewPhillips
                                          Capacitor Diarrhea - Nichicon PL Series
                                          by DrewPhillips
                                          Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                                          The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                                          03-02-2025, 10:18 PM
