Xbox360 shows E74 error on TV Screen, how to fix
+ More Options
Posts
  • tester2
    • Sep 2012
    • 28
    • ca
    hi guys i need your help, i got xbox360 shows E74 error on TV screen. so i did the following things, still not success.
    1)-i did x-clamp on to heat sinks with thermal past etc, still i am getting same error E74.
    2)-i did this back on the board, i remove 4 elastic white past (by manufacturar comes this elastic white paste there) & i put thermal past treatment then reattach that 4 elastic paste back on it, still E74 error shows on TV.
    based on your experience, what is the best solution to fix this error. and its look like software error may be, because my mothermoard looks very new inside. so "how to fix Software error E74",.
    or if you know any j-tag technique to fix this xbox360, please let me know, i will give a try.
    hopefully waiting for your replies.
    thanks for your help.
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Xbox360 shows E74 error on TV Screen, how to fix
    According to wikipedia, is sounds like a problem with the video scaler chip.
    Hope that helps,
    -Ben
    Muh-soggy-knee
    • trebo
      • 514
      • Wales, UK
      could try this, http://www.youtube.com/watch?v=0katvvV3ric
      • Phaihn
        • Jan 2009
        • 842
        how manny red rings does the console display?
        My Computer.
        AMD APU A4-3300 2.5ghz 1mb cache
        Motherboard GigaByte GA-A75M-S2V
        Kingston HyperX Blue DDR3 8GB (2x4GB)
        SB Audigy 2 ZS [B800] Sound Card
        500GB WD Caviar® Blue™
        1 Terabyte WD Caviar® Black™
        2 Terabyte WD Caviar® Black™
        • tester2
          • Sep 2012
          • 28
          • ca
          hi there only one red light shows.
          thanks
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            last one i had that did this i fluxed and reflowed the scaler.its still going a year later.it was a trashfind by my neighbors son.
            • tester2
              • Sep 2012
              • 28
              • ca
              hi guys, i did Oven Cook today for 2 hours 15 minutes, after done that, then i connect to TV. Now when i power ON then for a second i saw "xbox360 screen only one time" then i am getting Right side bottom 1 red light on for a second, there after this light goes off then on Left side i am getting 2 red lights ON continously, & on TV nothing shows.
              so there is no more E74 error on tv, just black screen shows, so what i can do in this situation, hope i get some success, if you guys give me some advice. as i read "2 red light means - over heating problem", so how to solve over heating problem.
              thanks for your replies.
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                Did you remove all the capacitors? If not, they probably boiled/exploded...
                Muh-soggy-knee
                • tester2
                  • Sep 2012
                  • 28
                  • ca
                  i wrap it up almunium foil on all 4 sides, then i did oven cook.
                  thanks
                  • Lobo
                    • May 2010
                    • 59
                    Follow this guide word for word
                    http://www.llamma.com/xbox360/repair...-clamp_fix.htm
                    Especially the reflowing part.
                    The oven trick should have been your last resort. And the way I've gotten the oven trick to work was to preheat the oven to 500 F. Double wrap the board in foil, leaving the top and bottom of GPU and Scaling chip exposed. Bake for about 2-5 minutes.
                    But for the love of your XBOX, get the right tools like a hot air rework station and some no clean liquid flux.
                      Two hours?????
                      Commercial reflow is done for TWO MINUTES!
                      I think it is toast!
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        Originally posted by tom66
                        Two hours?????
                        I know, right?!
                        I'm betting the capacitors exploded...
                        So many people think the oven/towel trick will do the job, but there is a 10% chance that it will fix the device ...
                        Muh-soggy-knee
                          master hoarder
                          • May 2008
                          • 12175
                          Should have done more searching/Googling.
                          http://xbox-experts.com/errorcodes.php
                          E74 is (or rather would have been in your case) an easy fix most of the time. 2 hours in the oven likely cooked all of your caps. You need to replace them before doing anything else now (IMO not worth it - Xboxes are cheap these days). Oven method works for PS3s but not for Xboxes.
                          Towel tricks and x-clamp "fixes" are even more retarded - DON'T DO THEM, EVER! IT WILL RENDER YOUR XBOX UNREPAIRABLE OVER TIME, EVEN FOR PEOPLE WHO DO PROFESSIONAL REBALLING FOR A LIVING. Whoever came up with those methods needs to be . Even a cheap heat gun reflow is better than those "fixes".
                          • tester2
                            • Sep 2012
                            • 28
                            • ca
                            thanks any ways guys, you all are right, mostly capacitors blow out on my board, when i did the oven cook, so i am not doing this testing any more.
                            thanks
                            • Ryan.man
                              by Ryan.man
                              02-04-2025, 12:23 PM
                            • smic717394
                              by smic717394
                              07-25-2024, 10:16 AM
                            • Sus256
                              HISENSE 65E7KQ PRO - no boot
                              by Sus256
                              Hi all!
                              HISENSE 65E7KQ PRO
                              RSAG7.820.13512 - chassis
                              MT9618BAATAB - cpu
                              RSAG7.820.12059 - power
                              HD650Y3U77 - panel
                              KLM8G1GETF - emmc
                              Replaced emmc.
                              Terminal log
                              UART
                              AC_ON
                              E-B
                              FDE enabled
                              06-01-2025, 02:11 AM
                            • David82827372
                              Dropped MacBookPro 15” 2012 shows black screen
                              by David82827372
                              MacBookPro 2012 15” A1398.
                              No visual damage was found.
                              Mac was inside of suitcase and it was inside of a bag.
                              Mac boots up,I can hear the chime,but the screen is totally black,not even “light” black. Caps lock light doesn't work.
                              I tried SMC,PRAM reset, didn't work.
                              Reconnecting screen display by unplugging those two things didn't work. I used this video
                              Reconnecting battery didn't work.
                              I also tried SMC,PRAM reset while the battery was disconnected and Mac was getting...
                              01-12-2024, 08:16 AM
                            • aaabddoo
                              Dell 3520 intel vga error when i instel vga intel driver The screen flickers need help pls
                              by aaabddoo
                              Dell Precision 3520​ intel vga error when Run the programl vga intel driver The screen flickers need help pls
                              Sorry for the language
                              06-15-2025, 02:42 PM
