Motor Run Capacitor in AC unit
  • LilKevin715
    • Apr 2006
    • 22
    The hot summer days from the heat wave around a month ago here in southern california took its toll on my Air Conditioning unit. I tried to turn it on a few days ago as usual..., but the unit would not start up. A quick call to a friend who services AC units got me back up and running again. There was a bad motor run cap that was obviously bulging
    Replacement cap was bought locally for around $15, MUCH cheaper than calling some random AC repairman from the yellow pages. Just though I would share this experience with you guys.
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: Motor Run Capacitor in AC unit
    My brother had the same problem with a large window unit he uses to cool his ranch house.
    Ludicrous gibs!
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      in a good season i can fill a 5 gallon pickle bucket with motor caps failed like that just from window units i rebuild to sell.sometimes they blow up or spit out the terminals.
      • arneson
        • Sep 2005
        • 1267
        OMG Moby Cap, Thar she blows.
        Jim
        • gonzo0815
          • Feb 2006
          • 1600
          Are that AL elektrolytic caps? metall paer should not bulge that way, but may be a litle expensive at that capacity.
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            iirc they are paper/oil dielectric.
            • japlytic
              • Oct 2005
              • 2086
              Might tell that to the man at the locan junkyard.
              • MORETTIGIAN
                Capacitor detached from PCB – RTX 2070 Super Founders Edition
                by MORETTIGIAN
                Title:
                Description:
                During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                I did not notice it detaching, so I am unsure of its original location on the PCB.
                Procedure performed:
                - Removed backplate
                - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                - Reapplied thermal compound
                - Reassembled card
                Observed behavior after reassembly:
                - GPU powers on and operates normally under...
                09-18-2025, 12:14 PM
              • Per Hansson
                Motor run capacitor physical size vs voltage rating & measurements?
                by Per Hansson
                (TL;DR skip the first paragraph)
                I encountered my first dead motor run capacitor at a customer this week.
                For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
                (Unless a servo motor makes more sense that is).
                But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
                The pump would run but sometimes trip the 10A breaker.
                I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
                Then it could...
                09-20-2020, 06:32 AM
              • Prolog
                RTX 3080 FE Identifying capacitor
                by Prolog
                Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                I hope these photos make it clear which component I am referring to:
                (yes, the soldering is a bit botched from removing the blown one, I know)
                I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                12-01-2024, 08:27 PM
              • Gjackson
                Air-conditioning unit power supply failing to power up
                by Gjackson
                Hi all, I managed to narrow down which PCB was causing my Haier AC to throw out an E7 error code (E7 indicates that the indoor unit and outdoor unit cannot communicate). I found that the outdoor unit power board which gives 5v and 15v to the outdoor unit module board fails to fully power up.. The power Led starts to fade in incredibly slowly and the 5v and 15v power buses jump around like crazy and never reach their required voltage. I unplugged the module board from the power board and the power board powered up fine! It had a steady 5v and 15v out and the power LED came on instantly and Bright....
                01-08-2022, 09:24 AM
              • chth96
                If I replace with inferior capacitor, Is it No harm to other IC components at all?
                by chth96
                I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                I know that these capacitor will not last as long as nichicon capacitor...
                12-22-2023, 04:34 AM
