TI83+ graphing calculator
Mann-Made Global Warming.
- Dr Seuss
Re: TI83+ graphing calculator
For the one with the totally black screen. Try turning it on, then (press 2nd, release it, then press the down arrow) repeat 15 times or so and see if the screen is better.Comment
by tommy97Hi,
I’ve been dealing with some stick drift issues on PS5 DualSense controllers. I’ve replaced the analogs on 4 different controllers using parts from 3 different suppliers (Mobile Sentrix and some from eBay), but I’m still getting slight drift, around 0.01 to 0.05 — only noticeable when zoomed in on the DualSense test GUI.
Anyone else had this happen even after replacing the sticks? Not sure if it’s the parts, or fault with the controller, or just how sensitive these are. Would really appreciate any tips or suggestions!... -
by dbuergiHi all,
I got a controller where the left stick was moving left all the time (-1.00 at calibration tool). Even after changing to hall effect sticks it stayed the same and reset and all others things didn't help.
I removed the stick again and even without it calibration tool shows a movement to the left. Anybody knows where the fault can come from? Maybe any bridges or damaged SMD components? -
by C152HeavySamsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
Summary for TL-DR readers:
• VCC pin (18) of PFC... -
by ponteleyApparently same as RX-V681/RX-V781/RX-A760/RX-A860
Everything working fine when plugged in and turned on.
Output voltages on all speaker terminals are few mV.
As time goes by (10-20 minutes), FR chanel goes to 10mv>100mv>200mv>300mv and up to 3V and then PROTECTION kicks in.
Very strange issue. Can't find anything blown/overheating/shorted/open.
All diodes and transistors checking out OK. Resistors too.
Can't find service manual or schematic....
Any help is greatly appreciated.-
by R7027Hello everyone!
I am looking for an alternative to the Power-Z USB power meter, like the model KM001. Are there no alternatives to this? Other than other models from the same company? This is a very popular meter that repair pros use.
I have a very simple and inexpensive USB power meter. I think it costed around 20 - 30 USD. I'm looking to upgrade it to one that has the logging and graphing functions like the one I mentioned above. Something in the same price range of 80 - 100 USD. Any suggestions?
I actually have a DC power supply that has a USB port... - Loading...
