Yamaha TSR-7810 receiver power drift
  • ponteley
    • May 2020
    Apparently same as RX-V681/RX-V781/RX-A760/RX-A860
    Everything working fine when plugged in and turned on.
    Output voltages on all speaker terminals are few mV.
    As time goes by (10-20 minutes), FR chanel goes to 10mv>100mv>200mv>300mv and up to 3V and then PROTECTION kicks in.
    Very strange issue. Can't find anything blown/overheating/shorted/open.
    All diodes and transistors checking out OK. Resistors too.
    Can't find service manual or schematic....
    Any help is greatly appreciated.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    Re: Yamaha TSR-7810 receiver power drift
    You got any high resolution pictures to show?
    • sanalelevenstar
      Yamaha RX-V485 receiver. After encountering a "version error"
      by sanalelevenstar
      I'm having trouble with my Yamaha RX-V485 receiver. After encountering a "version error", the USB, Bluetooth, and network functions have stopped working, making it impossible to perform a firmware update through normal methods.
      After doing some research on forums, I found that earlier Yamaha models with similar issues (like the internal error message) could be fixed by shorting or soldering specific pads—such as R896—and then powering on the unit to enter a service/boot mode that displays the model info and allows recovery.
      I managed to find the service...
      09-10-2025, 01:54 AM
    • Pete D
      Yamaha HTR-5460 Receiver protection code info.
      by Pete D
      Hi Guys, My first time on the forum.
      I have a Yamaha HTR-5460 Receiver that I have used for a few years. It has recently developed a problem of giving a pop in the speakers and then shutting down. This is intermittent and might happen after an hour or a couple of days of playing.
      I have put it into Diagnostic Mode and it comes up with code “PS PRT 020 B”. According to the service manual “PS PRT” signifies a power supply problem in the mains transformer, 5V or 12V DC supplies. I'm assuming that the “020 B” part of the code would define which one of these...
      11-03-2023, 07:00 AM
    • alfredomfr1
      YAMAHA AV Receiver RX-V585 No Power
      by alfredomfr1
      120v ok, No voltage on the connectors, Fuses OK, 165v DC on the main capacitor...
      09-12-2023, 09:47 AM
    • CDNBrewer
      Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
      by CDNBrewer
      Hello Everyone,
      I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
      Symptoms:
      • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
      • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
      • I swapped the Left and Right surround
      08-05-2025, 09:29 PM
    • wolf1976
      wireless receiver for 6 speeds fan control with remote control
      by wolf1976
      hi i have a receiver that is destroyed from the overvoltage i guess
      my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
      the motor fan has not label
      i have an other receiver operational
      In your opinion can i measure the voltage at the output ?
      what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
      thanks in advance...
      07-23-2025, 03:12 PM
