I'm hoping I can get some ideas on what to check in this old (1978) soviet-era electronic calculator I got from a flea market, the Elektronika EPOS-73A.
Got it home and plugged it in. It worked just fine at first, I used it a few times for a few minutes each time, "kid with new toy" style.
Then I disassembled it to clean the plastic case and the keys. I couldn't separate the lower half of the case from the board because cables are tied to it, so during the cleanup one of the cables going from the power board to the main board detached, and a leg from one of the capacitors broke.
I re-attached the cable, replaced the capacitor, and now the calculator doesn't work anymore. The display shows "111" in the first few digits instead of "0", with other digits not turning on or doing so dimly. Button input doesn't change what's shown.
It has a reset button, when I press it it sometimes shows nothing, other times shows "999" or "ººº".
I noticed when taking photos for this post that if I press (slightly bend) the board in different places I get some of the digits to be brighter, and that one of the K264YM2 (which according to google translate is a "three display amplifier") is getting hot.
Regardless of the thing with the cable and the cap, I think something worked just enough when I turned it on the first time, and now has decided it's old enough to retire
Next time I check on it I'll reflow the connections in the back in case it's a bad solder joint.
I would like some general advice on, for example, how to properly measure the power board, and if someone has worked with this kind of old device, maybe some more specific recommendations?
Photos:
Working
Power board
main chip
Display as it is now when plugged-in
Photos:
Working
Power board
main chip
