Elektronika EPOS-73A stuck with fixed display
  • carlitosbala
    • Feb 2021
    • 22
    • Uruguay
    I'm hoping I can get some ideas on what to check in this old (1978) soviet-era electronic calculator I got from a flea market, the Elektronika EPOS-73A.
    Got it home and plugged it in. It worked just fine at first, I used it a few times for a few minutes each time, "kid with new toy" style.
    Then I disassembled it to clean the plastic case and the keys. I couldn't separate the lower half of the case from the board because cables are tied to it, so during the cleanup one of the cables going from the power board to the main board detached, and a leg from one of the capacitors broke.
    I re-attached the cable, replaced the capacitor, and now the calculator doesn't work anymore. The display shows "111" in the first few digits instead of "0", with other digits not turning on or doing so dimly. Button input doesn't change what's shown.
    It has a reset button, when I press it it sometimes shows nothing, other times shows "999" or "ººº".
    I noticed when taking photos for this post that if I press (slightly bend) the board in different places I get some of the digits to be brighter, and that one of the K264YM2 (which according to google translate is a "three display amplifier") is getting hot.
    Regardless of the thing with the cable and the cap, I think something worked just enough when I turned it on the first time, and now has decided it's old enough to retire
    Next time I check on it I'll reflow the connections in the back in case it's a bad solder joint.
    I would like some general advice on, for example, how to properly measure the power board, and if someone has worked with this kind of old device, maybe some more specific recommendations?
    Photos:
    Working
    Power board
    main chip
    Display as it is now when plugged-in
    • 31156
    Re: Elektronika EPOS-73A stuck with fixed display
    the heater voltage/current is too high - you will kill the display if you keep running it.
    the wires shouldnt glow like that - check the psu caps.
    as it's soviet/communist there should be schematics available.
    • carlitosbala
      • Feb 2021
      • 22
      • Uruguay
      I had forgotten about this thread
      Thank you for your reply, I ended up taking the calculator to an electronics repair shop for diagnostic to avoid causing more damage while testing. The guy at least confirmed the power supply board looks OK, but apart from that was unable to find a fault and just told me that IC is bad and I should try to get a replacement.
      I'm tempted to try removing it from the board and powering it, in my mind the best case scenario is the calculator should work and just have one of the digits not showing. If the IC is shorting the circuit to ground then removing it should also remove the excess current. Especially if I replace it with a resistor to compensate for the chip's voltage drop. However, I'm also afraid that might be disastrous so I don't think I'll try it, at least not until I try finding that chip for some time.
        • 31156
        find the schematics for it - then address the heater voltage
        • redwire
          • 3912
          The VFD looks just like an IV-18, I used one in an Icetube Clock.
          • carlitosbala
            • Feb 2021
            • 22
            • Uruguay
            Just an update: I got schematics, for the calculator itself (there is an emulator project at SourceForge, https://sourceforge.net/projects/emulator-epos-73/), the display controller chip, and the processor. However, their usefulness is limited by the fact I don't understand Russian and Google Translate doesn't help that much because the PDFs are images and not actual text.
            As for further testing, I played with the potentiometers in the power and main boards, and there is a position where the display shows a "0" and the wires don't glow as much. But the calculator is still unresponsive, nothing changes when I hit buttons. Unplugging and plugging it again not always gets it again in that "0" state.
            Took the "faulty" display chip out but nothing changed either. I noticed that the chip doesn't get as hot depending on what is being displayed, so I guess it is not faulty after all and is just getting hot because is being overdriven and always on.
            At one hand, I'm thinking if maybe some of the orange components (which I assume are transistors) might be faulty and not giving the processor the right initialization signals. But I need to first confirm they are transistors, and then read enough of the schematics to identify proper replacements in case some are actually faulty.
            Finally, what if the problem is that this thing wants ~220V and is just not liking the current ~240V mains voltage? It would be problematic because it would mean those first few times when I plugged it and it worked I was in fact causing a failure, but in any case I dont have equipment to help me test that theory, unfortunately
              • 31156
              attach the schematic
              • carlitosbala
                • Feb 2021
                • 22
                • Uruguay
                The most complete documentation is what is there in SourceForge, really. Or at least that is the best I can find. It's 37MB, I'd assume attaching it is not possible
                  • 31156
                  i'll take a look
                  • Stunt
                    Hp Laptop Stuck on Hp protected by hp sure start screen
                    by Stunt
                    Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                    I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                    I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                    Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                    screen that's it and stuck there. I left it until the following day and i still...
                    09-02-2025, 01:51 PM
                  • stormanimal83
                    Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
                    by stormanimal83
                    Hey....
                    Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
                    my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
                    01-18-2024, 02:15 PM
                  • Ukdigger
                    Sony KDL-40EX403 Stuck on Standby Fixed
                    by Ukdigger
                    This TV was stuck on standby, all the voltages tested ok. I Googled the problem
                    and found that the ambient sensor could be causing the problem. I disconnected the two leads going to the ambient sensor (on the infra red remote sensor board) and the TV worked with no problems.
                    05-23-2022, 02:34 AM
                  • ekozeko333
                    [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                    by ekozeko333
                    I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                    🔥 The Problem Started After Suspected ESD/PD Fault
                    I experienced a power issue or ESD event through a USB-C charger
                    After that, the NX20P5090 power switch was visibly burned and was replaced
                    Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                    🧠 What I’ve Done So Far
                    Flashed...
                    06-21-2025, 02:48 AM
                  • duwane
                    MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
                    by duwane
                    Hi All.
                    I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
                    Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
                    After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
                    Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to...
                    10-17-2023, 07:48 PM
