Sharp Microwave - no backlight
    replied
    Re: Sharp Microwave - no backlight
    if the leds are in series a bad one will stop them all
    having said that - it doesnt look like they are driven hard
  • gurj1979
    replied
    Originally posted by R_J
    If it is a R-959, the display is an LCD with 10 led backlights (D10~D19) in series with a driver transistor Q2
    Thanks RJ. Sounds right about the number of LED's. There's a good few of them in series. So if I replace that tranny, then all should be good ? Do I need to replace and SMD caps too ?
  • gurj1979
    replied
    Originally posted by stj
    is that really the part number? or is it R959?
    You're correct. it's R959. I must have gotten mixed up with numbers.
  • R_J
    replied
    replied
  • R_J
    replied
    Are you sure it uses a backlight or is it a VF Display? post pictures of the control board
  • gurj1979
    started a topic Sharp Microwave - no backlight
    Need help fixing mums Sharp microwave oven combi.
    R-595 (sl)a
    Backlight has gone. Can still see digits buy super dim.
    Anyone with microwave experience help me out here ?
  • Superbee_dad
    Sharp 80” long short flash backlight error - Help
    by Superbee_dad
    Hello Sharp TV experts
    Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
    > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
    > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
    01-24-2025, 11:51 PM
  • Misterfixit
    Sharp LC-58Q7330U No Backlight
    by Misterfixit
    This set has the known reputation of failed led backlights. The set does not turn on, but when plugged in, the power led stays lit for about 5 seconds followed by two short blinks and then it repeats itself. While shinning a flashlight on the screen, you can make out the Sharp logo, then it goes out and repeats the cycle. I measured some voltages across the led backlight connector. What has me puzzled is that when I place the negative lead of my vom on the led backlight pin connector (in which the black wire going to the leds was), I measure as high as -228volts, and then it falls to -95 volts...
    06-04-2023, 07:39 PM
  • triplefour
    by triplefour
    09-13-2023, 10:43 PM
  • Misterfixit
    sharp LC-50LB601U No backlight
    by Misterfixit
    I have a sharp LC-50LB601U that has no backlight. It starts up fine, and has sound, however, I can only see the screen using a flashlight. I took the tv back off and measured voltages at the power supply connector CN-8601. As you can see by the picture, the led connector has 2 sets of 2 red wires and 2 sets of black wires going to the led backlights. Between each set of black wires and corresponding red wires, I measure 30 volts (pins 1 and 4) and 30 volts from pins 8 and 12. From ground to each set of red wires ( pins 1 and 12 to ground), I measure 35 volts. This voltage seems very low compared...
    04-04-2023, 01:21 PM
  • DanPoka
    Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
    by DanPoka
    I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
    Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
    This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
    02-15-2025, 05:05 AM
