Xbox One Original missing 12v enable signal
  • tccyo22
    • Oct 2019
    • 73
    Hi there, I have an Xbox One original in which I have all the 1.8v, 3.3v and 5.0v standby power rails present, however my 12v rail is not turning on and the enable signal PSU_V12P0_EN from the SMC to turn the power supply on is missing. There is high resistance on this line so it's not shorted directly to ground which leaves me with not many options.
    Was looking at a schematic and see the enable is created by the SMC. I have 3.3v on SMC_RST_N_IN but I'm a little stuck on where to look next. Is it likely that the SMC has gone bad or am I missing something else (it's my first time with the original xbox motherboard)?
    A visual inspection of the board reveals nothing that stands out of the blue and overall looks in fairly good condition aside from a light dust build up as expected.
    When I press the power button the white LED comes on for a second before going off, and the light on the PSU is yellow, only goes white for a second when I plug it in and switch it on.
  • tccyo22
    • Oct 2019
    • 73
    Re: Xbox One Original missing 12v enable signal
    Update on this, it's not a dead SMC, if i hit the power button enough times I get a spike of 12v on the 12v rail but only for about half a second before it falls back to about 0.6v/0.5v and drains down for a second or 2 before dropping to ~200-300mV. I'm trying to figure out why it gets brought back down. With the speaker plugged in I get the power on sound and sometimes tapping away fast enough also the power down, but most times just the power on sound.
    If anyone can share insight on how the 12v enable signal functions, how the SMC should react and what areas I should turn my attention to and double check, I would greatly appreciate it
      • 30964
      probably an overload.
      if you have a bench supply you can feed the 12v line with a volt and see how much current it draws.
      try not to feed over 1.5v, the lower the better incase a mosfet is shorted on the cpu supply.
      • tccyo22
        • Oct 2019
        • 73
        The mosfets around the CPU were the first thing I checked and the diode readings all read the same as a working board so I don't think injecting voltage is going to reveal anything.
        I think I might try replacing either U9F3 or U9C2 (or both) and see if that helps. I don't have a schematic or boardview for this specific board so I'm not sure where to find the PWRGOOD signals to check
        • miyagik
          • Jun 2018
          • 19
          • Mexico
          Any updates ?
          Having a similar problem
          • gurj1979
            Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
            by gurj1979
            Hey guys.
            Need help with this one.
            Fan not spinning due to missing PWN Fan signal.
            Also 5 seconds from powering up it freezes, unless in BIOS.
            But as soon as Windows starts to load, it will freeze.
            CPU is COLD / Room temp when it freezes.
            I've replaced the CPU, same problem.
            Replaced SIO/KBC IT8987e and reprogrammed - same problem.
            Replaced fan - same problem.
            Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
            Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
            08-19-2024, 05:22 PM
          • unimatrix93
            Xbox One 5V missing
            by unimatrix93
            Dear Forum,
            I'm stuck with this Xbox One.
            PSU stays yellow when connecting no power on when touching the button.
            I checked all the power rails and I found out that 5V is partially missing.
            5V is present on both the source and gate on U4B4 but missing on the drain.
            If I lift the gate's leg I get around 1.7Von the drain and the xbox beeps when I press the button but the PSU stays yellow, fan won't spin either....
            09-26-2024, 08:49 AM
          • Fernon@Repair
            MSI mpg b560m bazooka motherboard RSMRST# signal missing
            by Fernon@Repair
            I have MSI mpg b560m bazooka motherboard . this motherboard RSMRST# signal missing . i already reprogram bios but same condition
            My Motherboard this power stages are ok ...but 3vsb voltage have 4.17v (image added)
            VCCRTC ok
            RTCRST# ok
            ATX_5VSB ok
            SIO_3VA ok
            3VDSW ok
            DPWROK ok
            SLP_SUS# ok
            VSB_ENABLE# ok
            5VDUAL ok
            3VSB showing 4.17V
            PCH_1P8_VSB ok
            PCH_VCCIN_AUX ok
            RSMRST# No voltage
            this all voltages are ok but RSMRST# voltage is missing i did try to re program bios and change io but same...
            06-03-2025, 10:49 AM
          • ohren
            Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
            by ohren
            Hello!
            I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
            Measured voltages with no load:
            After rectifier diodes
            12V: 6.17 V
            5V: 5.67 V
            Secondary transformer pins AC measurement (really don't know if this says anything)
            12V: 2-2.5 V
            5V: 1.04 V
            I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
            03-18-2023, 10:33 AM
          • Prott
            Surface 7 - missing S3 sleep signal, S4 present but weird
            by Prott
            Hey fellow Badcappers
            I am troubleshooting Surface 7 board (rev 1.0) which was working great until it experienced a short circuit due to a bad screen.
            Now it's missing SLP_S3 signal. Everything in the power on sequence works properly up until that signal.
            - The resistance to ground on the SLP_S3 line is >50 kOhms.
            - No shorts on any powerrails that I can find.
            - I get a proper clock signal on the RTC crystal (XTAL_2P) once the Surface gets power.
            - SLP_S4 is, suprisingly, present, but it looks very weird (jump up to 2 V for about...
            07-08-2023, 04:54 PM
