Cummins ISX15 ECM component identification
  • gfosterCA
    • Dec 2019
    • 13
    Morning all,
    Have this ECM, p/n: 5317106 from a heavy truck.
    Report was pins 84+85 were not supplying necessary constant ground. Found this traumatized component which is in-line with the GND pins in question. I've located a similar component on-board, but would like to confirm.
    Anyone happen to know if references are available, or if someone might have one of these open on a bench?
    Could bridge, but suspect this may be for current sensing as well.
    Thanks in advance !
    • 31070
    Re: Cummins ISX15 ECM component identification
    it's either a resistor or a polyfuse self-resetting fuse.
    so something is shorted - probably in the truck wiring
    • gfosterCA
      • Dec 2019
      • 13
      I was thinking fuse, as it's completely open between the plates. As long as this isn't a current sense circuit through a resistor, I confuse it or temporary bridge to test functionality, I agree with your concerns, something either was applied to this line that shouldn't be there or something was accidentally shorted.
        • 31070
        there is another green thing on the board - see if it's a fuse
        • gfosterCA
          • Dec 2019
          • 13
          Resistor. Just unclear I'd this is the same component or same value.
          • CapLeaker
            Leaking Member
            • 8202
            I think you got to probe the two pads out and see what they are. Could be a fatal mistake if it was a cap and now you put a fuse or a resistor in.
            • gfosterCA
              • Dec 2019
              • 13
              Definitely not a capacitor. Either an SMD resistor or a fuse.
              • redwire
                • 3910
                If it's on a ground return, it would be a low-side current-sense resistor. You can see the instrumentation amp next to it. What are pins 84+85 going to?
                Automotive ECU standard requires all pins to tolerate short to GND, short to power. I guess Cummins doesn't play by that.
                I'd say 84+85 shorted to power somehow, probably mechanic pissing around.
                • R_J
                  • 9551
                  Can you identify the 8 pin smd ic next to the component? The burnt component might be the same as that R0499 current sense resistor, the circuit around the ic seems similar on both sides of the ic, two 102 resistors etc.
                  • CapLeaker
                    Leaking Member
                    • 8202
                    its guaranteed not a poly fuse.
                    • gfosterCA
                      • Dec 2019
                      • 13
                      I believe you are correct in that they are similar (or identical circuits). While this doesn't match the R0499, it does seem to match the physical characteristics of the SMD chip (SMSR040).
                      @redwire - these set of pins apparently go to a line heater. The current sense monitoring makes sense.
                        • 31070
                        a line heater?
                        i would have expected something like that to have a standalone module -it's not like it's needed in most of the world
                        • CapLeaker
                          Leaking Member
                          • 8202
                          What is / was the original complaint? Heater not working?
                          • corrize
                            Where to find a very small fpc connector 0.3mm between 2 pins ?
                            by corrize
                            Hello, I search this connector (oxydated).
                            It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                            I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                            I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                            Do you know how to find this connector please ? What is the exact name for find it ?
                            08-06-2024, 05:25 PM
                          • Powderfanupnorf
                            Dell AL440LX power on switch circuit help required
                            by Powderfanupnorf
                            Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
                            So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
                            My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
                            06-24-2024, 01:24 PM
                          • SS454
                            vizio e650i-a2 backlight flashes then turns off
                            by SS454
                            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                            panel: au optronics T650HVN05.4
                            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                            https://www.shopjimmy.com/vizio-56-0...-power-supply/
                            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                            08-20-2020, 03:57 PM
                          • DominanceINC
                            MSI Pro Z790-P Wifi 1missing CPU pins
                            by DominanceINC
                            I am a new forum member. I found a broken MSI motherboard with lot of problems. The other problems need schematic. Because, the missing parts what were breaking down with screwdriver and pliers at a standoff.
                            So, its actual problem is a missing Vcore and Gnd pins in the CPU socket. My question is that, can it be used safely without these two pins? Only for testing at first, while the other problems will be solved. I would wish repair them later.
                            The other spots are thermal phaste, because, the under educated installer of the CPU did wipe the contacts of the...
                            07-21-2025, 05:38 AM
                          • Shulgin
                            Acer predator XB241YU Component identification
                            by Shulgin
                            I have a problem with my Acer predator XB241YU screen. When I plug it in, the startup LED turns on instantly, and I can't turn off the screen without unplugging it.
                            After disassembly and inspection of the electronic cards I found what looks like a broken inductor, it is marked with the letter A and is at location L58.
                            In the first photo you can see the broken component, in the second photo you can see where it is on the board, in the third photo you can see the silkscreen and in the fourth photo you can see the identification sticker of the main board
                            I...
                            05-11-2024, 11:06 AM
