Ps4 saa-001 broken connector
  • Eniaro
    • Mar 2021
    • 77
    Does anyone know where I can run a jumper wire to I believe its a power supply cable connector
  • Mario875
    • Jun 2023
    • 15
    • Far Away
    Re: Ps4 saa-001 broken connector
    Directly to the via (small circle) that your arrow is pointing to is what I would use to be honest.
    • Eniaro
      • Mar 2021
      • 77
      I trust my skills however this came to me with the connector broken and glue was placed on to attempt to fix it (a kid tried to clean it) exposing the copper and soldering to it is a gamble IMO but I'll do it anyway
      • Eniaro
        • Mar 2021
        • 77
        maybe?
        Open to suggestions
        • R_J
          • 9623
          Here, watch this video https://www.youtube.com/watch?v=Nba6HsO7RBU
          Here is the via location on the other side of the board
          Just search Google images for ps4motherboard saa-001
          • Eniaro
            • Mar 2021
            • 77
            Thanks for the reply, I'll keep it in mind if I have to do this kind of repair again.
            My ghetto fix actually worked
            • e-repair
              Broken connector on an electric boat power steering
              by e-repair
              Hey, i have to repair an electronic board on an electric power stearing. the package was damaged during delivery and the connector was broken. but i can't find a part. the connector is the same BUT reversed as fiat power steering. I searched on digikey, mouser and aliexpress and i can't find any part similar. it's an uflex electric power steering, but i don't have more reference on the power steering block. if needed, i can buy any complete part just to recover the conector on the board and put it on this board...
              09-24-2025, 07:30 AM
            • Tomylee
              No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
              by Tomylee
              Sorry for the person who’s going to read all this !
              I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
              While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
              During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
              07-11-2025, 11:52 AM
            • gabri2211
              Xbox Series X Console Won't Turn On - Broken Nexus Connector on Mainboard
              by gabri2211
              Inside the console there is a small circuit board (see photo) that contains the main power switch, the one on the front.
              This circuit board connects to a 10-pin flat cable called NEXUS that terminates on the motherboard.
              This NEXUS connector broke.
              Can anyone tell me, while waiting for a replacement, if it's possible to turn on the Xbox by disconnecting this circuit board and making some modifications (like adding a small power button) on the motherboard?
              The Xbox has a power supply that provides 12 volts on all outputs, so the power...
              07-28-2025, 07:13 PM
            • 5mall5nail5
              Help identifying connector for ASUS 4090 Strix RGB LED connector
              by 5mall5nail5
              Hi All -
              I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
              Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
              05-04-2025, 07:47 AM
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
