PS5 BLOD- CFI-1115A Disc Version- Board= EDM-020
  • TheWizard
    • Feb 2015
    • 190
    Hey people I was wondering if I could get some pointers. I am new to working on the PS5. I only know power rail locations for this system from watching Cod3r. But here is my scenario. I have a EDM-020 board that has it's 12v, 5v, 3.3v rails. Even has the lower voltage rails. Everything seems to be fine. But system will not transfer from blue to white. Have the pulsing blue light of death. I checked the liquid metal on the APU and cleaned/reapplied. Havent checked under sticker yet due to no shorts being found. I am wondering if maybe i just have a bad BIOS chip or flash. I have a programmer if someone has a known good bin for CFI-1115A. Any help would be appreciated. Thanks!
  • TheWizard
    • Feb 2015
    • 190
    Re: PS5 BLOD- CFI-1115A Disc Version- Board= EDM-020
    Just to elaborate a bit on this.. I did check thermal temps on board while BLOD flashes. RAM, APU, SSD etc... all running at 40 degrees or lower.
    • aktinson
      PS Lover
      • May 2023
      • 18
      It sounds like you've done a good job of troubleshooting so far. Since all of the power rails seem to be present, and you've checked the thermal temps on the board, it's possible that you may have a bad BIOS chip or flash, as you mentioned.
      If you have a programmer and are able to access the BIOS chip, you could try flashing a known good bin for CFI-1115A. Alternatively, you could try searching online for a known good BIOS dump for your specific board model.
      Another thing you could try is reseating all of the board connections, especially the ones for the power supply and the storage drive. Sometimes a loose connection can cause the pulsing blue light of death.
      If none of these solutions work, it may be worth reaching out to a professional repair service that specializes in PS5 repairs or reach out to sony: https://www.playstation.com/en-us/support/hardware/
      I hope this helps!
      • TheWizard
        • Feb 2015
        • 190
        Aktinson,
        Much appreciated. Yeah it's been fun. I have a programmer and can pull the BIOS chip off to backup, erase and flash. But i do not have a known good BIN for CFI-1115A Disc edition. Any ideas where i can find? In regards to the connections. All good there. Thank you for the reply
        • Chikaubah
          Chikaubah commented
          Editing a comment
          Please could you snap the programmer you are using because i have a ch341a programmer but it doesn’t detect my ps5 chip but if i try a random chip it detect it so i dont know what going on i did sometimes downgraded my ch431a programmer to 3v because it came with 5v so if i can see your that will help
      • TheWizard
        • Feb 2015
        • 190
        Update: Removed board and connected to DC power supply. Providing 12 volts and 1 amp current. Looks to be a small short somewhere. This should be fun to find. Haha
        • TheWizard
          • Feb 2015
          • 190
          Not able to find a short on this board. This is like a needle in a haystack without a schematic I did confirm no liquid metal spill. Re-applied liquid metal and and same issue.
            • 31258
            remove and dump the syscon flash,
            i'm sick of people asking for dumps so it's time to start creating a collection.
            • TheWizard
              • Feb 2015
              • 190
              Anyone know what the full part number of this chip is? It is located right beside the buck controller. 1st pic shows buck controller to left and un-identified chip to the right. 2nd pic is un-identified chip zoomed in.
              • TheWizard
                • Feb 2015
                • 190
                Not even sure the flash i have on this chip was not previously corrupted.
                • TheWizard
                  • Feb 2015
                  • 190
                  Still battling this one. I have all the power rails. PS5 beeps, turns on. Pulsing blue light and no switch to white. But remains on. Thermal camera shows everything running at from 40-50 degrees celsius. APU , RAM, SSD, all warm. I have removed the BIOS chip and backed it up. My friend offered me to remove his bios chip from known good ps5 as well. Plan is to flash his known good bin to my chip. But what do i need to change in Hex Editor prior to flashing? We want to cross all our t's on this process. I need to know where to find the Model, Serial and any other relevant info that will need to be copied prior to flash. Any ideas?
                    • 31258
                    i dont know if it's just the dvd key and maybe a checksum.
                    if you unplug the dvd you can flash the non-drive syscon firmware and it works
                    • lotas
                      • Jan 2016
                      • 4803
                      • Russia
                      On PS4, this behavior was the same as you have on PS5 (not a working HDMI chip) and the set-top box did not boot to the end.
                      • TheWizard
                        • Feb 2015
                        • 190
                        Can you provide me a step by step walkthrough a bit? I have done this with Dell laptop BIOS's. The only main things to change in them BIN files are the Service Tag, Product Key, and MAC. I assume Sony has something similar? I have the W25Q16JV@SOIC8 backed up to BIN. What do i need to edit before flash. Those are the steps I am looking for. I am a noob with game console flashes.
                          • 31258
                          compare the 2 flashes for differences.
                          • TheWizard
                            • Feb 2015
                            • 190
                            Yeah i follow you. Is there any tips and tricks to working with HexEditor? I am not sure what i am looking for in the BIN.
                            • TheWizard
                              • Feb 2015
                              • 190
                              Okay i just was able to find the model through hex editor on both bin files. The known good is a CFI-1116B and my original is a CFI-1115A. I was told this BIN would work for my EDM-020 board though. Thoughts?
                              • TheWizard
                                • Feb 2015
                                • 190
                                Lotas,
                                So you think i have a bad hdmi encoder chip?
                                  • 31258
                                  use a hex editor that can DIFF 2 binaries.
                                  maybe 010 editor or imhex
                                  https://www.sweetscape.com/download/010editor/
                                  https://github.com/WerWolv/ImHex
                                  • TheWizard
                                    • Feb 2015
                                    • 190
                                    Stj,
                                    I did use a hexeditor and compared the two binaries. But other than model and serial number. What else do i have to change before flashing the chip?
                                      • 31258
                                      your missing the point,
                                      your comparing them to find out what is different.
                                      because nobody knows - or they arent sharing what they have found.
                                      i have ONE CFI-1015 dump,
                                      thats all i can find online - nobody is sharing shit because the people doing comercial repairs probably think it's some type of asset.
                                      that or they are scared of sony.
                                      • Tynan Dill
                                        by Tynan Dill
                                        Assuming...
                                        11-22-2024, 01:46 PM
                                      • m1ch43lzm
                                        by m1ch43lzm
                                        05-12-2025, 08:37 PM
                                      • Junior††
                                        PS5 Disc Not Supported/ Disc Not Recognized Board Num: EDM-020
                                        by Junior††
                                        Good Afternoon fellas,
                                        Issue:
                                        Disc is showing as not supported when a disc is put in.
                                        Here's what I've done, you can skip this if you just wanna know the question:
                                        - replaced with a disc drive from a donor ps5 (honestly questionable if this is known to work)
                                        - reflowed the disc drive connector
                                        -reflowed the chip in question (shown on image)
                                        - I will say this console was very dusty so it's conceivable that it got so hot that it made the chip joints cold and potentially other things on the board
                                        Question:
                                        I...
                                        02-19-2025, 12:48 PM
                                      • howardc64
                                        by howardc64
                                        07-24-2025, 05:17 PM
                                      • Hakuu
                                        by Hakuu
                                        Hi There,
                                        More Details
                                        TV Model - LG OLED77G1PUA
                                        07-12-2023, 02:37 PM
