PS5 BLOD- CFI-1115A Disc Version- Board= EDM-020
  • diif
    • Feb 2014
    • 6978
    • England
    #81
    Re: PS5 BLOD- CFI-1115A Disc Version- Board= EDM-020
    Originally posted by TheWizard
    Fuse is a 0603 Timed(slow blow) 3 a 6v. I can find fuses but not 0603 3 amp with 6v. All the voltages i am finding are much higher
    Are you sure it's 3A, it looks like it's 2A to me.
    • TheWizard
      • Feb 2015
      • 190
      Not completely positive. Just what i was informed. But here is the fuse I am looking for. Ideas? https://kasynparts.com/product/ps5-b...e-replacement/
        • 31257
        so the question is how fast vs how expensive.
        aliexpress or digikey?
        • diif
          • Feb 2014
          • 6978
          • England
          #84
          It looks like a round dot in this post. https://www.badcaps.net/forum/showpo...7&postcount=72
          • TheWizard
            • Feb 2015
            • 190
            Exactly "stj".
            Diif, Sorry was a horrible picture after the downsize for upload. I snapped a new one. Here you go. "T"
            • TheWizard
              • Feb 2015
              • 190
              Originally posted by stj
              so if it's rated for 250v your fine.
              fuses dont blow based on voltage - only the current matters
              So this would work right?
              https://www.digikey.com/en/products/...00-TM/15204247
                • 31257
                thats fine if it is 3a you need
                • TheWizard
                  • Feb 2015
                  • 190
                  To be honest i dont know what I need. Just going by what i was told.What would be the best way for me to test. I was also told the fuse is probably a 0402 fast blow. Instead of 0603 slow blow. Frustrating not having a schematic
                    • 31257
                    0402 vs 0603 you can check with a vernier
                    • TheWizard
                      • Feb 2015
                      • 190
                      Just making sure to match up the voltage because i don't want an arc to happen.
                        • 31257
                        either will handle more that a ps5 has in it
                        • TheWizard
                          • Feb 2015
                          • 190
                          Fixing this thing to flip it. I want to get all the right parts lol
                            • 31257
                            well 0402 is a lot smaller than 0603, so get the correct size or soldering it in wont be easy
                            • TheWizard
                              • Feb 2015
                              • 190
                              The issue Phil has here sounds like my issue now that the southbridge is back to normal. Just watched his vid here tonight. This PS5 may have been trolling me with the Southbridge issue. https://youtu.be/IevHM3oDUvg. Going to follow Phil's troubleshooting and see if we can land this plane haha. Still need the fuse and cap values he replaces here but it's a start.
                              • TheWizard
                                • Feb 2015
                                • 190
                                Ordered the replacement for the A2 chip along with fuses. Went with 0402 3a 24v. That was the lowest i could find. Pretty sure its just the chip and the fuse most lilely blew from when i injected voltage.
                                • sadenki
                                  • Feb 2018
                                  • 7
                                  • france
                                  #96
                                  Can you post your dump of your board ? (EDM-020)
                                  • TheWizard
                                    • Feb 2015
                                    • 190
                                    Any idea what the value is of this power inductor?
                                      • 31257
                                      maybe if you check the size in mm and then look at inductors at digikey you can get an idea
                                      • TheWizard
                                        • Feb 2015
                                        • 190
                                        Yeah was going down that road. Playing the reference game. Haven't measured the part yet. Will keep you posted.
                                        • TheWizard
                                          • Feb 2015
                                          • 190
                                          I am hoping this works per the a2 chip's datasheet. https://www.mouser.com/ProductDetail...G5yjipLg%3D%3D
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • Junior††
                                            PS5 Disc Not Supported/ Disc Not Recognized Board Num: EDM-020
                                            by Junior††
                                            Good Afternoon fellas,
                                            Issue:
                                            Disc is showing as not supported when a disc is put in.
                                            Here's what I've done, you can skip this if you just wanna know the question:
                                            - replaced with a disc drive from a donor ps5 (honestly questionable if this is known to work)
                                            - reflowed the disc drive connector
                                            -reflowed the chip in question (shown on image)
                                            - I will say this console was very dusty so it's conceivable that it got so hot that it made the chip joints cold and potentially other things on the board
                                            Question:
                                            I...
                                            02-19-2025, 12:48 PM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
                                          • Hakuu
                                            by Hakuu
                                            Hi There,
                                            More Details
                                            TV Model - LG OLED77G1PUA
                                            07-12-2023, 02:37 PM
