Need bios repair Asus CS-B REV 1.03
  • OKRPKCOMP
    • Dec 2020
    • 439
    • PAKISTAN
    CS-B/COM/SI rev 1.03
    Backup attached
    waiting for help
    • 21845
    Re: Need bios repair Asus CS-B REV 1.03
    Backup attached
    waiting for help
    https://www.asus.com/Commercial-Moth...HelpDesk_BIOS/
    Open the bios with UEFITool ,right click on "AMI Aptio capsule" and select "Extract body"
    UEFITool - https://github.com/LongSoft/UEFITool..._A57_win32.zip
    • OKRPKCOMP
      • Dec 2020
      • 439
      • PAKISTAN
      Backup attached
      waiting for help
      The fault is that, when i turn on motherboard, fan spins and off
      On off continuesly, but when i remove bios from board, and turn on the board
      Fans continuesly runs
      So i think board,s bios is corrupted
      • OKRPKCOMP
        • Dec 2020
        • 439
        • PAKISTAN
        Sir, three times back i also requested for asus motherboard bios and i got the site link from here, but with respect i tell u. after extracting and flashing bios, problem not solved and when i got the same board and copy bios to infected board, it works fine
        But sometimes i took bios from site and make it bin from cap through uefi tool. it works fine, but so many times the bios of site is not working
          • 21845
          Its a hardware problem
          when i remove bios from board, and turn on the board Fans continuesly runs
          Normal behaviour
          Try an older bios version
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • grimacelord
            by grimacelord
            07-10-2025, 02:52 PM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
          • throwaway327
            by throwaway327
            Model No: RC72LA
            Serial No: SBNVKD001014459
            06-18-2025, 05:52 PM
          • ferah831208
            help with bios decompose for Asus s5506ma
            by ferah831208
            I have an Asus s5506ma that was bricked after a Windows update supposedly when it was updating bios. It seems to be a meteorlake Intel CPU core ultra, I cannot find too much info regarding this hardware, anyone have info about if it contains Intel ME engine and if there is any tool for disassemble spi image like we do with all CSME or TXE versions using the appropriate Intel ME tool? The problem is original bios file Asus provides, has bios guard protection, I downloaded the latest update for Ami_pfat_extractor from plomatov (previous versions of AMI bios guard extractor doesn't work),with that...
            08-24-2025, 05:35 PM
