Need bios repair Asus CS-B REV 1.03
  • OKRPKCOMP
    • Dec 2020
    • 439
    • PAKISTAN
    CS-B/COM/SI rev 1.03
    Backup attached
    waiting for help
    • 21860
    Re: Need bios repair Asus CS-B REV 1.03
    Backup attached
    waiting for help
    https://www.asus.com/Commercial-Moth...HelpDesk_BIOS/
    Open the bios with UEFITool ,right click on "AMI Aptio capsule" and select "Extract body"
    UEFITool - https://github.com/LongSoft/UEFITool..._A57_win32.zip
    • OKRPKCOMP
      • Dec 2020
      • 439
      • PAKISTAN
      Backup attached
      waiting for help
      The fault is that, when i turn on motherboard, fan spins and off
      On off continuesly, but when i remove bios from board, and turn on the board
      Fans continuesly runs
      So i think board,s bios is corrupted
      • OKRPKCOMP
        • Dec 2020
        • 439
        • PAKISTAN
        Sir, three times back i also requested for asus motherboard bios and i got the site link from here, but with respect i tell u. after extracting and flashing bios, problem not solved and when i got the same board and copy bios to infected board, it works fine
        But sometimes i took bios from site and make it bin from cap through uefi tool. it works fine, but so many times the bios of site is not working
          • 21860
          Its a hardware problem
          when i remove bios from board, and turn on the board Fans continuesly runs
          Normal behaviour
          Try an older bios version
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • pirati
            by pirati
            Yesterday, 04:20 PM
          • grimacelord
            by grimacelord
            07-10-2025, 02:52 PM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
          • throwaway327
            by throwaway327
            Model No: RC72LA
            Serial No: SBNVKD001014459
            06-18-2025, 05:52 PM
