How to extract bios file from latest Hp bios updates?
  • ASB
    • Dec 2020
    • 133
    • Pakistan
    Need bios file from attached exe file for Hp pc. If there is an easy method like Dell PFS extract, kindly mention it as well. Thanks.
    • 21149
    Re: How to extract bios file from latest Hp bios updates?
    Run the exe and choose the copy option,it will copy to C:\SWSetup\SP135602 .The exe`s sometimes crash on win 7 .Win 8,10 and 11 are usually ok,if the exe still crashes choose an older update.
    • ASB
      • Dec 2020
      • 133
      • Pakistan
      I need bin file to repair original file. Winrar/ winzip cannot extract bin file from this exe file.
      • imranromi
        • Jan 2015
        • 1288
        • Pakistan
        Here your bid bios.
        • ASB
          • Dec 2020
          • 133
          • Pakistan
          Originally posted by imranromi
          Here your bid bios.
          Thank you so much for your help. Can you please tell me how you did this?
          • khawajaimran
            • Apr 2018
            • 3
            • pakistan
            • survivalbloke
              Unable to extract bios file from Lenovo bios exectuable
              by survivalbloke
              I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
              Code:
              "innoextract 7wcn38ww.exe"
              it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
              The trouble I'm having is that I'm not getting the newly...
              06-12-2024, 07:55 AM
            • survivalbloke
              Unable to extract Lenovo BIOS file from installer
              by survivalbloke
              I'm working on a Lenovo LOQ 15APH8, Serial# MP2L9MAV. I want to flash a new BIOS onto it, but I'm also trying to learn this process for my own enrichment and professional development.
              I was watching some tutorials, copying the serial info blocks from the old bios to a new bios. Before that though, they use innoextract on the Lenovo .exe. I downloaded Innoextract v1.9 but it tells me my .exe is not a supported inno setup installer(see screenshot). So if I unpack this using 7zip, I do get a .ROM file, but according to my tutorials, I'm looking for a .FD file.
              How can...
              07-16-2025, 03:21 PM
            • Citymin
              by Citymin
              S/N : 5RNK9FFT70...
              08-05-2025, 05:12 AM
            • iZakre
              HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
              by iZakre
              Hello everybody!
              To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
              The thing is that I had installed TeamViewer and could log into the computer...
              02-19-2023, 02:27 PM
            • Forest79
              by Forest79
              However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
              07-23-2023, 07:39 AM
