How to extract bios file from latest Hp bios updates?
  • ASB
    • Dec 2020
    • 133
    • Pakistan
    Need bios file from attached exe file for Hp pc. If there is an easy method like Dell PFS extract, kindly mention it as well. Thanks.
    • 21853
    Re: How to extract bios file from latest Hp bios updates?
    Run the exe and choose the copy option,it will copy to C:\SWSetup\SP135602 .The exe`s sometimes crash on win 7 .Win 8,10 and 11 are usually ok,if the exe still crashes choose an older update.
    • ASB
      • Dec 2020
      • 133
      • Pakistan
      I need bin file to repair original file. Winrar/ winzip cannot extract bin file from this exe file.
      • imranromi
        • Jan 2015
        • 1290
        • Pakistan
        Here your bid bios.
        • ASB
          • Dec 2020
          • 133
          • Pakistan
          Originally posted by imranromi
          Here your bid bios.
          Thank you so much for your help. Can you please tell me how you did this?
          • khawajaimran
            • Apr 2018
            • pakistan
            • to5it0
              by to5it0
              10-24-2025, 01:35 AM
            • survivalbloke
              Unable to extract bios file from Lenovo bios exectuable
              by survivalbloke
              I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
              Code:
              "innoextract 7wcn38ww.exe"
              it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
              The trouble I'm having is that I'm not getting the newly...
              06-12-2024, 07:55 AM
            • survivalbloke
              Unable to extract Lenovo BIOS file from installer
              by survivalbloke
              I'm working on a Lenovo LOQ 15APH8, Serial# MP2L9MAV. I want to flash a new BIOS onto it, but I'm also trying to learn this process for my own enrichment and professional development.
              I was watching some tutorials, copying the serial info blocks from the old bios to a new bios. Before that though, they use innoextract on the Lenovo .exe. I downloaded Innoextract v1.9 but it tells me my .exe is not a supported inno setup installer(see screenshot). So if I unpack this using 7zip, I do get a .ROM file, but according to my tutorials, I'm looking for a .FD file.
              How can...
              07-16-2025, 03:21 PM
            • Citymin
              by Citymin
              S/N : 5RNK9FFT70...
              08-05-2025, 05:12 AM
            • m1ch43lzm
              by m1ch43lzm
              Hi everyone
              09-06-2025, 05:47 PM
