I need a BIOS .bin of asus x470 TUF
  • battlebox
    • Mar 2021
    • 8
    • Algeria
    hello to all,
    anyone have bios .bin for this motherbord asus x470 tuf gaming plus
    post your bios backup , thank you
    • 21853
    Re: I need a BIOS .bin of asus x470 TUF
    Originally posted by battlebox
    hello to all,
    Download this bios from asus support
    https://dlcdnets.asus.com/pub/ASUS/m...NG-SI-4008.zip
    Use UEFITool to remove the 2kb CAP header.
    https://github.com/LongSoft/UEFITool..._A55_win32.zip
    Open the bios with uefitool, right click on AMI Aptio Capsule, Extract Body .
    • battlebox
      • Mar 2021
      • 8
      • Algeria
      it's converted .Rom ! the programer didn't write it? I need the bios backup .bin ?!
      the programer didn't read my bios !! I think it's empty
        • 21853
        Just rename it to .bin .Are you using a CH341A
        • battlebox
          • Mar 2021
          • 8
          • Algeria
          yes CH341A
          • battlebox
            • Mar 2021
            • 8
            • Algeria
            and the EZP2019 software
            • battlebox
              • Mar 2021
              • 8
              • Algeria
              I do rename it to .bin and used FD44Editor ! to put seial number ,system UUID and primery card MAC ...I need the system UUID and address MAC!?I need to put those information on BIOS to flash it ! so I need backup .bin of x470 to copy info with FD44Editor , and past it in new BIOS.
                • 21853
                Try NeoProgrammer or AsProgrammer software with the CH341A
                https://www.badcaps.net/forum/showpo...04&postcount=7 NeoProgrammer
                https://www.badcaps.net/forum/showpo...6&postcount=10 AsProgrammer
                Are you using a sop8 clip or have you desoldered the chip.Desoldering it is the most reliable way. If you do manage to make a backup post it here.Check the backup with a hex editor,it may look empty, as in all FF`s but scroll down further and there should be code.An AMD bios has a different layout to intels,there`s no flash descriptor or ME region.
                FD44editor can only add to one area,and the info is usually stored in more than one place,you need to use UEFITool and a hex editor to do it right.
                • battlebox
                  • Mar 2021
                  • 8
                  • Algeria
                  thanks ,I tried both there is no chip mx25u25645gz4 ! I used RT809F another programer
                  and it's work fine
                  I read the chip first , I found the bios 4012 was on motherbord I took the address MAC and system UUID with FD44Editor to convert the new BIOS, just there is no post same problem no boot ! I tried many bios version ! and same problem after flashing! everything work fine ram ,cpu,gpu... ! and no boot even the keybord and mouse didn't light up!
                  • battlebox
                    • Mar 2021
                    • 8
                    • Algeria
                    I don't desoldered the chip there is 8pin of Bios on x470 ! so I used pinout cable and verify the pinout with a continuity tester.
                    • razor_amd
                      by razor_amd
                      12-15-2020, 07:07 PM
                    • grimacelord
                      by grimacelord
                      07-10-2025, 02:52 PM
                    • jbonavita
                      by jbonavita
                      Some issues
                      Things I tried
                      04-29-2025, 09:38 PM
                    • throwaway327
                      by throwaway327
                      Model No: RC72LA
                      Serial No: SBNVKD001014459
                      06-18-2025, 05:52 PM
                    • lrouw84
                      by lrouw84
                      Hi there,
                      01-28-2023, 01:31 PM
