I need a BIOS .bin of asus x470 TUF
  • battlebox
    • Mar 2021
    • 8
    • Algeria
    hello to all,
    anyone have bios .bin for this motherbord asus x470 tuf gaming plus
    post your bios backup , thank you
    • 20419
    Re: I need a BIOS .bin of asus x470 TUF
    Originally posted by battlebox
    hello to all,
    Download this bios from asus support
    https://dlcdnets.asus.com/pub/ASUS/m...NG-SI-4008.zip
    Use UEFITool to remove the 2kb CAP header.
    https://github.com/LongSoft/UEFITool..._A55_win32.zip
    Open the bios with uefitool, right click on AMI Aptio Capsule, Extract Body .
    • battlebox
      • Mar 2021
      • 8
      • Algeria
      it's converted .Rom ! the programer didn't write it? I need the bios backup .bin ?!
      the programer didn't read my bios !! I think it's empty
        • 20419
        Just rename it to .bin .Are you using a CH341A
        • battlebox
          • Mar 2021
          • 8
          • Algeria
          yes CH341A
          • battlebox
            • Mar 2021
            • 8
            • Algeria
            and the EZP2019 software
            • battlebox
              • Mar 2021
              • 8
              • Algeria
              I do rename it to .bin and used FD44Editor ! to put seial number ,system UUID and primery card MAC ...I need the system UUID and address MAC!?I need to put those information on BIOS to flash it ! so I need backup .bin of x470 to copy info with FD44Editor , and past it in new BIOS.
                • 20419
                Try NeoProgrammer or AsProgrammer software with the CH341A
                https://www.badcaps.net/forum/showpo...04&postcount=7 NeoProgrammer
                https://www.badcaps.net/forum/showpo...6&postcount=10 AsProgrammer
                Are you using a sop8 clip or have you desoldered the chip.Desoldering it is the most reliable way. If you do manage to make a backup post it here.Check the backup with a hex editor,it may look empty, as in all FF`s but scroll down further and there should be code.An AMD bios has a different layout to intels,there`s no flash descriptor or ME region.
                FD44editor can only add to one area,and the info is usually stored in more than one place,you need to use UEFITool and a hex editor to do it right.
                • battlebox
                  • Mar 2021
                  • 8
                  • Algeria
                  thanks ,I tried both there is no chip mx25u25645gz4 ! I used RT809F another programer
                  and it's work fine
                  I read the chip first , I found the bios 4012 was on motherbord I took the address MAC and system UUID with FD44Editor to convert the new BIOS, just there is no post same problem no boot ! I tried many bios version ! and same problem after flashing! everything work fine ram ,cpu,gpu... ! and no boot even the keybord and mouse didn't light up!
                  • battlebox
                    • Mar 2021
                    • 8
                    • Algeria
                    I don't desoldered the chip there is 8pin of Bios on x470 ! so I used pinout cable and verify the pinout with a continuity tester.
                    • razor_amd
                      by razor_amd
                      12-15-2020, 07:07 PM
                    • throwaway327
                      by throwaway327
                      Model No: RC72LA
                      Serial No: SBNVKD001014459
                      06-18-2025, 05:52 PM
                    • jbonavita
                      by jbonavita
                      Some issues
                      Things I tried
                      04-29-2025, 09:38 PM
                    • lrouw84
                      Asus vivobook s510ua bios changed to x510un
                      by lrouw84
                      Hi there,
                      I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                      I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                      01-28-2023, 01:31 PM
                    • DynaxSC
                      by DynaxSC
                      06-14-2024, 03:49 PM
