hp prodesk 600 g1 original bios
  • Graku
    • May 2017
    • 27
    • Spain
    Re: hp prodesk 600 g1 original bios
    Good morning to all,
    I am looking for BIOS for HP Prodesk 600 G1 (Tower). Does anyone have anything available?
    Thank you very much for any help provided. Thanks.
    • peste
      • Dec 2016
      • 13747
      • ROMANIA
      post the original bios..
      • Graku
        • May 2017
        • 27
        • Spain
        Hi everybody!!
        BIOS Original HP Prodesk 600 G1 Tower.
        I think it is corrupt because the motherboard turns on, no video and no sound, the CPU fan is put at full power. If I remove RAM it gives error code of lack of RAM.
        • mrwab
          Banned
          • Jan 2014
          • 83
          • morocco
          Originally posted by graku
          hi everybody!!
          Bios original hp prodesk 600 g1 tower.
          I think it is corrupt because the motherboard turns on, no video and no sound, the cpu fan is put at full power. If i remove ram it gives error code of lack of ram.
          try and replay
          • afaruky
            • Jun 2020
            • 8
            I don't have a backup of the original bin. I wrote one of the files given here. System boots but MAC is FF:FF......
            What are my options?
            Thanks.
            • hoaca388
              Badcaps
              • Jan 2022
              • 12420
              #26
              Thanks.
              Can you find your device's MAC address? And which bios file did you use?
              ​https://www.badcaps.net/donate
                • 22109
                Thanks.
                The MAC address will be in your old bios,if you have it,or on a sticker on the motherboard.You can add the MAC using a hex editor or with software
                https://www.badcaps.net/forum/showpo...10&postcount=4
                • afaruky
                  • Jun 2020
                  • 8
                  Unfortunately, it's not written on anywhere. I couldn't find any label with MAC address.
                  I used one of your files.
                  https://www.badcaps.net/forum/showpo...8&postcount=13
                  I want to believe any MAC address should work unless it's FF:FF:.... Does MOBO check the validity of MAC and disable the NIC?
                  NIC on the board is Intel I217-LM. I couldn't find the appropriate EeUpdate.exe file for this one.
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12420
                    #29
                    I don't know if it's the same as a laptop, on HP laptops the MAC address can also be found in the EC file.
                    • afaruky
                      • Jun 2020
                      • 8
                      Do I really need the original MAC to get ethernet card to work? Even if I do, is there a way to embed MAC address to bin file and flash the BIOS?
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12420
                        #31
                        Q _ Do I really need the original MAC to get ethernet card to work ?
                        A _ That is obvious.
                        Q _ Even if I do, is there a way to embed MAC address to bin file and flash the BIOS ?
                        A _ Yes , you can. See the images under.
                        • afaruky
                          • Jun 2020
                          • 8
                          I used another dump from an identical model and it works. Now I will change it to a random MAC address to eliminate duplicates on the same network. It seems there is no control mechanism to authenticate the original MAC address of NIC, as long as it has an acceptable one.
                          Thanks a lot!
                          • mob71
                            • Oct 2022
                            • algeria
                            #33
                            • Graku
                              • May 2017
                              • 27
                              • Spain
                              #34
                              Originally posted by mrwab
                              try and replay
                              Thanks, I'll try. I haven't done it yet as I had other urgent issues that came as a surprise. As soon as I try it, I'll let you know.
                              Thanks.
                              • Graku
                                • May 2017
                                • 27
                                • Spain
                                #35
                                Unfortunately I have tried the provided BIOS but it doesn't work for me. Anyone have another dump for the Prodesk 600 G1 TWR? Thanks in advance.
                                • hardware1
                                  • Sep 2021
                                  • 2949
                                  • N/A
                                  #36
                                  Try this one, it's a clean bios from hp.
                                  all donations are welcome,
                                  • Graku
                                    • May 2017
                                    • 27
                                    • Spain
                                    #37
                                    Thank you so much for everything,
                                    I just tried it and it works. The only problem I have now is that I don't have a MAC in the BIOS. Everything comes out f
                                    Does anyone know how to edit the MAC on the Prodesk 600 G1?
                                    I appreciate any help.
                                    • hardware1
                                      • Sep 2021
                                      • 2949
                                      • N/A
                                      #38
                                      Try and give me the results.
                                      • Graku
                                        • May 2017
                                        • 27
                                        • Spain
                                        #39
                                        Sorry for not responding earlier, I have to say that with this new version I already have a MAC. Thank you very much for your work. Now my daughter already has the equipment working.
                                        Thanks again.
                                        • abdelilahocs
                                          • Nov 2018
                                          • 119
                                          • morroco
                                          #40
                                          hp prodesk 600 g1
                                          merlin rev a
                                          biios extracted from dead mother
                                          • ianasystems
                                            Need Help Restoring BIOS and MAC Address for HP ProDesk 600 G1 SFF
                                            by ianasystems
                                            I'm currently dealing with a BIOS corruption issue on my HP ProDesk 600 G1 SFF desktop PC.
                                            After the BIOS got corrupted, my PC was showing no display, and I had to take it to a repair shop where the technician removed the BIOS chip from the motherboard and installed a BIOS I provided from a file I downloaded from the official HP website.
                                            While the display issue was fixed and the system is powering up again, there's one major problem: the Ethernet MAC address is now showing as FF:FF:FF:FF:FF:FF, indicating that it's been wiped or corrupted as well....
                                            04-16-2025, 02:04 PM
                                          • Vesko356
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • beBoss
                                            HP ProDesk 400 G6 mini - BIOS Password attempt to remove it
                                            by beBoss
                                            as noobie to this please excuse my lack of experience.
                                            I am trying to remove a BIOS password from this machine:
                                            HP ProDesk 400 G6 Mini
                                            but so far I still have no success.
                                            I bought CH341 programmer and decided to give it a try.
                                            The programmer came with 8 pin cables and connectors or whatever everything else is called so I had to buy a new 16 pin cable because the chip which I think is the BIOS is with 16 pins..
                                            I connected everything and downloaded AsProgrammer and NeoProgrammer then installed drivers...
                                            05-30-2024, 12:48 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • JoWed
                                            Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                                            by JoWed
                                            Hello Community,
                                            I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                                            07-01-2025, 09:32 AM
