Need Help Restoring BIOS and MAC Address for HP ProDesk 600 G1 SFF
  • ianasystems
    • Apr 2025
    • Pakistan
    I'm currently dealing with a BIOS corruption issue on my HP ProDesk 600 G1 SFF desktop PC.
    After the BIOS got corrupted, my PC was showing no display, and I had to take it to a repair shop where the technician removed the BIOS chip from the motherboard and installed a BIOS I provided from a file I downloaded from the official HP website.
    While the display issue was fixed and the system is powering up again, there's one major problem: the Ethernet MAC address is now showing as FF:FF:FF:FF:FF:FF, indicating that it's been wiped or corrupted as well.
    I downloaded the latest BIOS update from HP's support website, using my PC's serial number to get the correct update file.
    I extracted the BIOS bin file from the downloaded .exe using 7-Zip and gave it to the technician.
    The technician flashed the BIOS, and while the system is working again, the MAC address is gone, showing the default FF:FF:FF:FF:FF:FF.
    The technician mentioned that the BIOS file I gave him was an update file, not a BIOS dump, and that this might be the reason why the MAC address is missing.
    PC : HP ProDesk 600 G1 Small Form Factor PC
    PC Serial : 2UA5122MMV
    PC Product ID : G5R58UT#ABA
    Any help or advice would be greatly appreciated!
    Thank you in advance!​
  • hoaca388
    Badcaps
    • Jan 2022
    • 12406
    No bios file how can i help ? You must attach bios file when requesting.
    • ianasystems
      • Apr 2025
      • Pakistan
      Thank you for your response.
      I downloaded the BIOS from the HP website by entering my PC's serial number (HP ProDesk 600 G1 SFF - PC Serial : 2UA5122MMV) to get the correct BIOS version for my system.
      I used 7-Zip to extract the contents, and inside, I found the .bin BIOS file.​
        • 22096
        What hoaca388 wanted you to post was the contents of the bios chip on your motherboard, using an SPI programmer. Try MAC address tools, if they don`t work you will have to buy a programmer.
        Post 2 https://www.badcaps.net/forum/troubl...60#post1465160
        • to5it0
          by to5it0
          10-24-2025, 01:35 AM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • maanee11
          Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
          by maanee11
          Hello Everyone,
          I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
          It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
          In the website, you can only see specs etc.
          I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
          11-08-2025, 04:08 AM
        • m1ch43lzm
          by m1ch43lzm
          Hi everyone
          09-06-2025, 05:47 PM
        • Forest79
          by Forest79
          07-23-2023, 07:39 AM
