good day badcaps can you help me guys out there i need bios bin for Dell Optiplex 5055 slim type cpu.
Dell optiplex 5055 bios bin
Hello there, can you help me?
i legit Brick my motherboard by flashing via CMD..
somehow i force it to update to different board..
(I have Optiplex 5055 AMD A series, and it force update to Optiplex Ryzen Apu series)
Do you have Optiplex 5055 AMD A series Bios?
(i have hardware flasher, so bin file will be okay)
Thank you..
*i attached my *f'ed bios file..
** also sorry for my bad englishAttached Filesif you find these attachements useful please consider making a small donation to the site
Hi, i need bios for Dell OptiPlex 5055 Ryzen Small Form Factor.
Service Tag : J01BNX2
here my old bios backup
OptiPlex 5055 R Small Form Factor
Service Tag: J01BNX2Attached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donateComment
by mrrubikHi folks,
I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
Steps I took:- Read BIOS with CH341a, verified hash twice
- Patched
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
- Loading...
