Dell optiplex 5055 bios bin
  • ututino
    • Sep 2012
    • 4
    • philippines
    good day badcaps can you help me guys out there i need bios bin for Dell Optiplex 5055 slim type cpu.
    • 22108
    Re: Dell optiflex 5055 bios bin
    Post your bios backup .
    • ututino
      • Sep 2012
      • 4
      • philippines
      thank you sir..
        • 22108
        thank you sir..
        Thanks for what ? ,you havnt posted anything .
        • darkyamidesu
          • Aug 2018
          • Indonesia
          Hello there, can you help me?
          i legit Brick my motherboard by flashing via CMD..
          somehow i force it to update to different board..
          (I have Optiplex 5055 AMD A series, and it force update to Optiplex Ryzen Apu series)
          Do you have Optiplex 5055 AMD A series Bios?
          (i have hardware flasher, so bin file will be okay)
          Thank you..
          *i attached my *f'ed bios file..
          ** also sorry for my bad english
        • dqtech
          Badcaps
          • Jul 2018
          • 640
          • N/A
          Hi, i need bios for Dell OptiPlex 5055 Ryzen Small Form Factor.
          Service Tag : J01BNX2
          here my old bios backup
          • hoaca388
            Badcaps
            • Jan 2022
            • 12419
            OptiPlex 5055 R Small Form Factor
            Service Tag: J01BNX2​
            • dqtech
              Badcaps
              • Jul 2018
              • 640
              • N/A
              file working..thank you sir
              • mrrubik
                Dell Optiplex 7010 micro bad BIOS flash?
                by mrrubik
                Hi folks,
                I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                Steps I took:
                1. Read BIOS with CH341a, verified hash twice
                2. Patched
                12-23-2024, 04:11 PM
              • zenius
                by zenius
                12-08-2024, 06:13 AM
              • mikeybass
                by mikeybass
                04-23-2025, 04:30 PM
              • capoplays
                Help with BIOS update on Dell G15 5515 after chip replacement
                by capoplays
                Hey everyone,
                I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                When I check the BIOS using the F12 menu Flash...
                10-24-2025, 06:53 AM
              • Akhlz001
                by Akhlz001
                09-20-2025, 07:15 PM
