shuttle sk41g bios update?
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    found none on the shuttle site.
    iirc there was a homebrew out there that allowed these boards to take a xp3200 cpu.
    got 2 of these boxes in and have a few xp3200+ cpu's i would like to use.
    that is after the board and psu get recapped.
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Re: shuttle sk41g bios update?
    Isn't SK41G 133 FSB ?
    Ambitious to run 200 FSB processor
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      nope.
      its running an xp2500 right now at 2100 mhz
      just shows unknow cpu at xxxx.
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        base from info on site this should not support any cpu runing on 166/200 fsb (only supports 100/133 fsb) so only athlon is supported but not barton core
        Code:
        http://www.shuttle.eu/_archive/older/en/fx41.htm#mainboardfx4
        however, with overclocking...
        it uses FX41 board and bios can be found here:
        Code:
        http://download.shuttle.eu/Archive_2004/BIOS/fx41/
        ...it should solve not showing cpu type problem
        Im Back... sort of...
        • mikeybass
          by mikeybass
          04-23-2025, 04:30 PM
        • akwky
          by akwky
          Hi!
          04-14-2025, 01:56 PM
        • al3m0di
          Update bios EFCN58WW to EFCN59WW
          by al3m0di
          Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
          I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
          The BIOS version is EFCN58WW.
          When I turn on the device, it displays the message:
          "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
          The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
          I've tried
          07-29-2024, 10:32 AM
        • trix11
          Dell Precision T1650 MT Workstation bricked after BIOS update
          by trix11
          I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
          - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
          - Dell Precision T1650 mid tower Workstation
          - Xeon E3-1225 V2
          - 32Gb PC3-12800E RAM
          - 4Tb SATA HDD
          - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
          I see now that others have experienced like issues e.g.:
          - https://www.dell.com/community/Prec...
          10-24-2022, 10:35 PM
        • Julian Bailey
          BIOS update wont complete - Dell Latitude 7420
          by Julian Bailey
          Hi all
          Anyone come across this issue where a BIOS flash will only part complete?
          It will update the system BIOS and Primary EC BIOS fine but fails to update the Intel TBT Retimer, Intel TBT Retimer 2 and ME Firmware.
          NVMe m.2 drive isnt detected in the BIOS, but you can get into the BIOS fine and it all works in there as intended.
          The drive works fine in another laptop.
          Link to a video I made of what its doing here:
          Any ideas on how to overcome this?
          Cheers...
          06-02-2025, 01:39 PM
