shuttle sk41g bios update?
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    found none on the shuttle site.
    iirc there was a homebrew out there that allowed these boards to take a xp3200 cpu.
    got 2 of these boxes in and have a few xp3200+ cpu's i would like to use.
    that is after the board and psu get recapped.
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Re: shuttle sk41g bios update?
    Isn't SK41G 133 FSB ?
    Ambitious to run 200 FSB processor
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      nope.
      its running an xp2500 right now at 2100 mhz
      just shows unknow cpu at xxxx.
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        base from info on site this should not support any cpu runing on 166/200 fsb (only supports 100/133 fsb) so only athlon is supported but not barton core
        Code:
        http://www.shuttle.eu/_archive/older/en/fx41.htm#mainboardfx4
        however, with overclocking...
        it uses FX41 board and bios can be found here:
        Code:
        http://download.shuttle.eu/Archive_2004/BIOS/fx41/
        ...it should solve not showing cpu type problem
        Im Back... sort of...
        • mikeybass
          by mikeybass
          04-23-2025, 04:30 PM
        • akwky
          by akwky
          Hi!
          04-14-2025, 01:56 PM
        • al3m0di
          Update bios EFCN58WW to EFCN59WW
          by al3m0di
          Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
          I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
          The BIOS version is EFCN58WW.
          When I turn on the device, it displays the message:
          "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
          The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
          I've tried
          07-29-2024, 10:32 AM
        • capoplays
          Help with BIOS update on Dell G15 5515 after chip replacement
          by capoplays
          Hey everyone,
          I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
          The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
          When I check the BIOS using the F12 menu Flash...
          10-24-2025, 06:53 AM
        • 0xx
          2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
          by 0xx
          Hi folks,
          My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
          What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
          I assumed that Windows Update was interrupted due to closing...
          09-14-2025, 03:46 PM
