HP EliteDesk 800 G2 BIOS corrupted by HP bios update
  • GIFixed
    • Sep 2019
    • 61
    • Denmark
    After updating BIOS to:
    HP EliteDesk 800 G2 TWR/SFF
    02.42 Rev.A 17.2 MB 12. sep 2019
    corrupted the bios.
  • GIFixed
    • Sep 2019
    • 61
    • Denmark
    (link: https://ftp.hp.com/pub/softpaq/sp990...00/sp99042.exe)
    It finished flashing and rebooted - Does not POST at all.
    - Tried trick with Win key + B and power to recover.
    - Tried remove CMOS battery
    - Tried pressing CMOS button for 10 seconds
    Nothing of these helps.
    When taking power and draining remaining power, and then applying power again it do the following:
    RED power light and beeps 2 long and 4 short.
    By the way, the bin file is 9 MB in size.
    Thanks for any help
      • 22097
      Re: HP EliteDesk 800 G2 BIOS corrupted by HP bios update
      Post your bios backup .
      • GIFixed
        • Sep 2019
        • 61
        • Denmark
        Sorry, I cant find it
        Is there any other way to flash a working full BIOS?
        • RethoricalCheese
          • Mar 2013
          • 1519
          • Estonia
          Can't you dump your faulty bios? You can use that faulty bios and file from HP and combine them. When it's working, you might have to use dmifit tool to insert dmi information.
          • GIFixed
            • Sep 2019
            • 61
            • Denmark
            I will try to dump the BIOS chip using TL866 programmer.
            The windows HP bios update tool did take a backup of my bios. Its size is 9 MB. Same size as in the update tool.
            Then this should be not a full backup and useless, do you agree?
            By the way, I would like to learn how to edit/combine/fix bios files. Is there a good toturial?
              • 22097
              The 9MB file is the bios region,its the only part that gets flashed and backed up.The rest of the bios is locked,the flash descriptor and ME region.See the description here:
              https://winraid.level1techs.com/t/gu...lization/31277
              You can overwrite the bios region using a hex editor ,such as HxD .https://mh-nexus.de/en/hxd/
              • GIFixed
                • Sep 2019
                • 61
                • Denmark
                By the way,
                Any body knows why there are two flash chips in this machine:
                1) 25Q64FVSIQ near the Nuvoton NPCD315HA0DX
                2) 25Q128FVSQ near Infenion SLB9670 and the E16 header marked "ROM RCVRY".
                The E16 header is not populated (no pin header soldered).
                Could not find any pinout of this E16 2x5 pins header. Pin4 is key.
                Other HP models uses 8-pin recovery header with to CS# pins tied together by a jumper. What I could see on videos/tutorial you disconnect this jumper and attach external programmer directly to this header for dump and flashing bios without desoldering.
                Any help on this one?
                Is it possible to dump the full BIOS without desoldering on this machine. And without harming any other components?
                It seems this machine is still under warranty, but HP demands the purchase invoice to correct warranty expiration date. We are seeking to find the invoice. Until now not succeeded to find it.
                • GIFixed
                  • Sep 2019
                  • 61
                  • Denmark
                  We are checking the warranty with HP. Until then I prefer to be cautious to not void the warranty.
                  But anyways it is a good thing to learn about tackling this problem.
                  • RethoricalCheese
                    • Mar 2013
                    • 1519
                    • Estonia
                    There are soic8 clips so there is no need to unsolder most of the times.
                    • GIFixed
                      • Sep 2019
                      • 61
                      • Denmark
                      Yes, thanks, I am aware of that SOIC8 clip. But with this particular machine, does it fry the EC?
                      KvnTM told me before in another thread regarding Yoga 2 pro, that using a clip will fry the EC.
                      Is there a way or a rule to determine, if there are possibilities to destroy the EC or another components by flashing BIOS onboard using clip or direct connect?
                      • RethoricalCheese
                        • Mar 2013
                        • 1519
                        • Estonia
                        It will not fry any EC. You just have to use the correct voltage. If it is a 1.8V eeprom, use 1.8V programmer. If it is a 3.3V eeprom, use a 3.3V programmer.
                        Winbond eeprom with FV in the model is 3.3V. If it is FW instead, it is 1.8V.
                        • GIFixed
                          • Sep 2019
                          • 61
                          • Denmark
                          Nobody has an answer to why there are two flash chips on this elite desk 800 g2 model?
                          • RethoricalCheese
                            • Mar 2013
                            • 1519
                            • Estonia
                            One is main bios, other is EC bios.
                            • GIFixed
                              • Sep 2019
                              • 61
                              • Denmark
                              Thanks.
                              Could it be the EC bios that is corrupted?
                              • RethoricalCheese
                                • Mar 2013
                                • 1519
                                • Estonia
                                Try flashing clean main bios first, then you will know.
                                • GIFixed
                                  • Sep 2019
                                  • 61
                                  • Denmark
                                  I no longer have this G2 machine. The seller did exchange it for me with a better G3.
                                  Thanks for your help.
                                  • by_mex
                                    • Feb 2014
                                    • 57
                                    • turkey
                                    hi,
                                    HP EliteDesk 800 G2 main, bios please
                                    • peste
                                      • Dec 2016
                                      • 13728
                                      • ROMANIA
                                      Originally posted by by_mex
                                      hi,
                                      post the original bios here
                                      • by_mex
                                        • Feb 2014
                                        • 57
                                        • turkey
                                        ok wait pls
                                        • The_Memory_Guy
                                          Dell Latitude 5520 refusing Bios Update, Black screen no matter what I do
                                          by The_Memory_Guy
                                          Hi, if this needs to go in different category please let me know
                                          I have Dell Latitude 5520, however it refusing a Bios Update, the current Bios version 1.30. Its 11th gen with with an 1135 G7 CPU.
                                          I have tried everything under the sun to try and get this Laptop to update the Bios, Latest version 1.47, however It wont do the Bios Update, via Windows, Via USB, Via Network, same issue, in Windows it does the checks and says its restarting the laptop, however all I get is black screen, nothing after that, 15/20/30 minutes, even 1 hour after.
                                          I tried using the...
                                          Today, 12:16 PM
                                        • Datahoarder
                                          HP Elitedesk 800 G2 DM / Mini -> Can't get BIOS flashed, tried multiple. Update Brick
                                          by Datahoarder
                                          HP EliteDesk 800 G2 MINI/DM (1L PC)
                                          I have 40 of these units. All of which i tried to update bios with HP's utility got bricked. All of them were bios password locked, i used the jumper thing to reset it. Couple updated bios, one of which worked fine for _ONE_ boot. Second is now mixed with rest, i don't know which it is specifically so have not retested it.
                                          All had some MESpilock failed errors on (my) first boot of the unit.
                                          Photo: https://cdn.discordapp.com/attachmen...018_220853.jpg
                                          10-19-2023, 09:33 AM
                                        • FalconPunch
                                          Surface Pro X 1876 Bios corrupted
                                          by FalconPunch
                                          Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
                                          Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
                                          08-09-2025, 03:56 AM
                                        • Thomas Dunlap
                                          Corrupted/Interrupted Bios Update Lenovo Legion S7 15ACH6
                                          by Thomas Dunlap
                                          I have a Lenovo Legion S7 15ACH6 that was interrupted during a BIOS update and is now bricked. Symptoms: fans spin, RGB keyboard lights up, but no display/POST.
                                          The BIOS chip is a Gigadevice GD25LR128. I’m using a CH341A with a 1.8 V adapter. In AsProgrammer I selected GD25Q128 (since GD25LR128 isn’t listed) and successfully made a dump (BiosDump2_pf3eg12j.rar).
                                          My understanding is that I’ll need a known good BIOS dump for this exact model, ideally matched to my laptop’s serial number (PF3EG12J), and that the Windows license key/serial should also...
                                          09-26-2025, 12:45 PM
                                        • intelg
                                          HP Elitedesk 800 G6 lost BIOS admin password
                                          by intelg
                                          Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
                                          Here is the hardware identification specs:
                                          HP EliteDesk 800 G6 Desktop Mini PC
                                          Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                                          BIOS ver S21 Ver. 02.05.01 01/05/2021
                                          Born on date: 07/26/2021
                                          SN MXL11841GN
                                          SKU 3X8V9UCHABA
                                          UUID 8116E79EF6FFE94DB0B98A3188270C5C
                                          SYSTEM BOARD ID 8710
                                          SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
                                          11-03-2023, 02:05 AM
