HP EliteDesk 800 G2 BIOS corrupted by HP bios update
  • maksim-shvecov
    • Sep 2016
    • balakleya
    #81
    Re: HP EliteDesk 800 G2 BIOS corrupted by HP bios update
    Hi all.
    Please help with the bios
    HP 800 G2 MINI 35W
    810660-001
    • hardware1
      • Sep 2021
      • 2946
      • N/A
      #82
      Originally posted by maksim-shvecov
      Hi all.
      HP 800 G2 MINI 35W
      810660-001
      Here's your New Bios, program that file to your 16MB chip and put your 8MB chip back.
      Serial Number: MXL6271MVM.
      all donations are welcome,
      • robertson74
        • Jan 2023
        • 6
        • Hungary
        #83
        Dear All,
        Can I ask some help with my Hp EliteDesk 800 G2 pc?
        I have no display, the psu, ram modules and cpu are ok.
        2 long, 4 short beeps at startup.
        I've attached the original bios I read out with a CH341A
        Thank you,
        R
        • hardware1
          • Sep 2021
          • 2946
          • N/A
          #84
          Originally posted by robertson74
          Dear All,
          Thank you,
          R
          You should have another 8MB chip, find it and upload its content here.
          Also write your Device Serial Number.
          • robertson74
            • Jan 2023
            • 6
            • Hungary
            #85
            My elitedesk's S/N is: CZC61194R9
            I've attached my main and ec bios files.
            Thank you,
            R
            • hardware1
              • Sep 2021
              • 2946
              • N/A
              #86
              Thank you,
              R
              Your file with the name "orig_ec_bios" not good, try to read the chip again.
              • hoaca388
                Badcaps
                • Jan 2022
                • 12262
                #87
                No, both his files are not good.
                • robertson74
                  • Jan 2023
                  • 6
                  • Hungary
                  #88
                  How can I check that the readout was correct? My SO8-CLIPS is a bit worn.
                  • hardware1
                    • Sep 2021
                    • 2946
                    • N/A
                    #89
                    It will be better if you don't use a clip, you need to desolder the chips and solder it back after programming.
                    Read the 2 Chips again as @hoaca388 said.
                    • robertson74
                      • Jan 2023
                      • 6
                      • Hungary
                      #90
                      The attached zip contains the current bios files. I checked them after more readout, they were binary identical.
                      (In previous reads, AsProgrammer could not read the same binary twice in a row from the same chip, now I use neo programmer)
                      Unfortunately, I overwrote the main bios a week ago in the belief that I had a correct backup.
                      Check them please
                      Serial number (S/N): CZC61194R9
                      Thank you
                      • hardware1
                        • Sep 2021
                        • 2946
                        • N/A
                        #91
                        Check them please
                        Thank you
                        Here's your New Bios, Program that file to your 16MB chip and put your 8MB chip back.
                        • robertson74
                          • Jan 2023
                          • 6
                          • Hungary
                          #92
                          Thank you.
                          I've written the new bios and verified it.
                          -It turns on for 5 secs, turns off for 2 secs and repeats it endlessly.
                          -No error beeps
                          -No display
                          Any idea?
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12262
                            #93
                            Thank you.
                            -No error beeps
                            -No display
                            Any idea?
                            HP EliteDesk 800 G2 Base Model Small Form Factor PC
                            • robertson74
                              • Jan 2023
                              • 6
                              • Hungary
                              #94
                              I've downloaded bios files from the prev posts and one of them fixed my pc. (Orig+N01_0254+outimage.bin)
                              Thank you so much guys!
                              • bahtiyor
                                • Feb 2023
                                • Uzbekistan
                                #95
                                Originally posted by hoaca388
                                hp elitedesk 800 g2 base model small form factor pc
                                this file helped me a lot, thank you very much
                                • Pascal Komlassan
                                  • Jan 2017
                                  • 809
                                  • TOGO
                                  #96
                                  HP EliteDesk 800 G2 Tower (N01) (V_2.59) BIOS AND EC
                                  • magneh
                                    • Apr 2014
                                    • 607
                                    • Portugal
                                    #97
                                    Hey Everyone!
                                    Can someone help me removing the BIOS pwd on this dump?
                                    HP Elitedesk 800 G2 mini 35W
                                    motherboard: dolomite rev a
                                    Backup in attachment.
                                    Thanks in advance
                                    • peste
                                      • 13377
                                      • ROMANIA
                                      #98
                                      Originally posted by magneh
                                      Hey Everyone!
                                      Thanks in advance
                                      try..
                                      • magneh
                                        • Apr 2014
                                        • 607
                                        • Portugal
                                        #99
                                        Thanks Peste!
                                        Worked perfectly.
                                        • bazzbarro
                                          • Dec 2012
                                          • 25
                                          • kenya
                                          #100
                                          thanks
                                          Originally posted by satishkumar
                                          • Datahoarder
                                            HP Elitedesk 800 G2 DM / Mini -> Can't get BIOS flashed, tried multiple. Update Brick
                                            by Datahoarder
                                            HP EliteDesk 800 G2 MINI/DM (1L PC)
                                            I have 40 of these units. All of which i tried to update bios with HP's utility got bricked. All of them were bios password locked, i used the jumper thing to reset it. Couple updated bios, one of which worked fine for _ONE_ boot. Second is now mixed with rest, i don't know which it is specifically so have not retested it.
                                            All had some MESpilock failed errors on (my) first boot of the unit.
                                            Photo: https://cdn.discordapp.com/attachmen...018_220853.jpg
                                            10-19-2023, 09:33 AM
                                          • FalconPunch
                                            Surface Pro X 1876 Bios corrupted
                                            by FalconPunch
                                            Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
                                            Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
                                            08-09-2025, 03:56 AM
                                          • Thomas Dunlap
                                            Corrupted/Interrupted Bios Update Lenovo Legion S7 15ACH6
                                            by Thomas Dunlap
                                            I have a Lenovo Legion S7 15ACH6 that was interrupted during a BIOS update and is now bricked. Symptoms: fans spin, RGB keyboard lights up, but no display/POST.
                                            The BIOS chip is a Gigadevice GD25LR128. I’m using a CH341A with a 1.8 V adapter. In AsProgrammer I selected GD25Q128 (since GD25LR128 isn’t listed) and successfully made a dump (BiosDump2_pf3eg12j.rar).
                                            My understanding is that I’ll need a known good BIOS dump for this exact model, ideally matched to my laptop’s serial number (PF3EG12J), and that the Windows license key/serial should also...
                                            09-26-2025, 12:45 PM
                                          • intelg
                                            HP Elitedesk 800 G6 lost BIOS admin password
                                            by intelg
                                            Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
                                            Here is the hardware identification specs:
                                            HP EliteDesk 800 G6 Desktop Mini PC
                                            Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                                            BIOS ver S21 Ver. 02.05.01 01/05/2021
                                            Born on date: 07/26/2021
                                            SN MXL11841GN
                                            SKU 3X8V9UCHABA
                                            UUID 8116E79EF6FFE94DB0B98A3188270C5C
                                            SYSTEM BOARD ID 8710
                                            SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
                                            11-03-2023, 02:05 AM
                                          • Kashi1712
                                            HP Folio 1040 G1 corrupted bios - new bios flash, unable to update DMI
                                            by Kashi1712
                                            Hello all,
                                            I'm facing a strange issue, I do have my old bios where i can find some information about the laptop SN, build and so on for the DMI encoding.
                                            I did flash a new bios on the laptop and i have tried all the tools found everywhere on this forum and other forums but i'm unable to update all DMI info in the BIOS. I still get an error saying "Warning: Machine is not in committed state".
                                            Could somebody guide me on this or maybe help? I'm really hoping to find a way out of this bios thing...
                                            See attached old bios (corrupted...
                                            05-18-2023, 07:16 AM
