Dell XPS 8920 IPKBL-VM BIOS
  • Dinneke
    • Apr 2014
    • 154
    • Netherlands
    I need Dell XPS 8920 IPKBL-VM BIOS please
    • 21841
    Re: Dell XPS 8920 IPKBL-VM BIOS
    Post your bios backup .
    • Dinneke
      • Apr 2014
      • 154
      • Netherlands
      Here it is.
      • peste
        • Dec 2016
        • 13566
        • ROMANIA
        try...
        • Dinneke
          • Apr 2014
          • 154
          • Netherlands
          Took a while before i could test it....Not working sadly, no screen what so ever.
          • peste
            • Dec 2016
            • 13566
            • ROMANIA
            try again..
            • Dinneke
              • Apr 2014
              • 154
              • Netherlands
              Not working, no picture. Any alternatives?
                • 21841
                Try this one .
                • Dinneke
                  • Apr 2014
                  • 154
                  • Netherlands
                  Working fine! Thanks
                  • abdul hadi
                    Banned
                    • Sep 2019
                    • 7
                    • Newzealand
                    Originally posted by SMDFlea
                    Try this one .
                    Thank you come fast display.
                    • mferna14
                      • Jun 2018
                      • 1046
                      Hi all, I am working on this Dell XPS 8920 Desktop MB # IPKBL-VM ., no display at all. I programmed the Bin files listed in #8 & the behaviour of the desktop changed. It turns on/off 3~4 times like any normal Dell Desktop when we add a new CMOS battery. It goes through all it's self test modes but no display. Can someone do a cleanup of the Original Bin files I have posted (S. No 4GKNGK2 ), & am using an Intel i7-7700 CPU on this motherboard. I would really appreciate. Thanks in advance
                      • mferna14
                        • Jun 2018
                        • 1046
                        Any help will be greatly appreciated. Thanks
                        • hardware1
                          • Sep 2021
                          • 2948
                          • N/A
                          Here's your New BIOS, try it and give me results.
                          all donations are welcome,
                          • mferna14
                            • Jun 2018
                            • 1046
                            Thanks for the help, will try right now & inform you soon.
                            • mferna14
                              • Jun 2018
                              • 1046
                              @hardware1 thanks for the Bin files. The result is the same., No Display at all. CPU Fan spins for nearly 2-3 mins, turns off & then on again. Then again starts automatically & the same behaviour 2-3mins fan spin & then off again. Maybe a bit of errors there, pls. try again. Thanks
                              • hardware1
                                • Sep 2021
                                • 2948
                                • N/A
                                Same as your Original file or the file in Post #8?
                                • mferna14
                                  • Jun 2018
                                  • 1046
                                  @hardware1 thanks for the Bin files., I have tried both but none of them worked., I think problem is with the main motherboard, I will check. Thanks for all the help
                                  • zenius
                                    by zenius
                                    12-08-2024, 06:13 AM
                                  • mikeybass
                                    by mikeybass
                                    04-23-2025, 04:30 PM
                                  • capoplays
                                    Help with BIOS update on Dell G15 5515 after chip replacement
                                    by capoplays
                                    Hey everyone,
                                    I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                    The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                    When I check the BIOS using the F12 menu Flash...
                                    10-24-2025, 06:53 AM
                                  • Akhlz001
                                    by Akhlz001
                                    09-20-2025, 07:15 PM
                                  • gizaha
                                    by gizaha
                                    02-13-2024, 07:18 AM
