Asus B760M-A WIFI d4 bios
  • Olvin1
    • Jan 2025
    • 11
    • Česká Republika
    Good evening to everyone I'd like to ask you too much if you don't have a bios into the asus B760M-A Wifi d4 motherboard that could load directly into the winbond Bios chip downloaded from the Asus website can't be loaded onto the chip and I can't get it through the usb because the board won't be rolling at all .... Thank you very much everyone for your help
  • hoaca388
    Badcaps
    • Jan 2022
    • 12316
    PRIME B760M-A WIFI D4
    Write bios with programmer, cheapest model is CH341A.
    https://www.youtube.com/results?sear...mer+how+to+use
    • Olvin1
      • Jan 2025
      • 11
      • Česká Republika
      Thank you so much hopefully I'm going for it and yet once thank you
      • Olvin1
        • Jan 2025
        • 11
        • Česká Republika
        Hello After loading bios to chip the base board started working and uz works well🤗 , chip I had to solder and put it in the adapter right on the board it couldn't load ...but it's all right now and the board is starring !!😁 thank you so much and how can I reward myself?
        • grimacelord
          by grimacelord
          07-10-2025, 02:52 PM
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • throwaway327
          by throwaway327
          Model No: RC72LA
          Serial No: SBNVKD001014459
          06-18-2025, 05:52 PM
        • mozzwald
          ASUS Prime Z790-P WIFI D9 BIOS Trouble
          by mozzwald
          Failed BIOS flash caused no post/fan spin/flashing power led. I have backed up both chips (8 & 16mb) after failed flash. I extracted BIOS from ASUS site and flashed it to 16MB chip but same problem. It appears the ME version in the backup is very old (16.1.25.1865) and not even listed in the ASUS downloads page so I assume the ME update failed. I tried extracting the ME firmware from new ASUS bin/cap file and flash it to the 8MB chip but same issue. Not sure what to do to recover from this. Any help appreciated.
          10-01-2025, 07:21 PM
