Asus B760M-A WIFI d4 bios
  • Olvin1
    • Jan 2025
    • 13
    • Česká Republika
    Good evening to everyone I'd like to ask you too much if you don't have a bios into the asus B760M-A Wifi d4 motherboard that could load directly into the winbond Bios chip downloaded from the Asus website can't be loaded onto the chip and I can't get it through the usb because the board won't be rolling at all .... Thank you very much everyone for your help
  • hoaca388
    Badcaps
    • Jan 2022
    • 12419
    PRIME B760M-A WIFI D4
    Write bios with programmer, cheapest model is CH341A.
    https://www.youtube.com/results?sear...mer+how+to+use
    • Olvin1
      • Jan 2025
      • 13
      • Česká Republika
      Thank you so much hopefully I'm going for it and yet once thank you
      • Olvin1
        • Jan 2025
        • 13
        • Česká Republika
        Hello After loading bios to chip the base board started working and uz works well🤗 , chip I had to solder and put it in the adapter right on the board it couldn't load ...but it's all right now and the board is starring !!😁 thank you so much and how can I reward myself?
        • grimacelord
          by grimacelord
          07-10-2025, 02:52 PM
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • pirati
          by pirati
          10-27-2025, 04:20 PM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • throwaway327
          by throwaway327
          Model No: RC72LA
          Serial No: SBNVKD001014459
          06-18-2025, 05:52 PM
