Good evening to everyone I'd like to ask you too much if you don't have a bios into the asus B760M-A Wifi d4 motherboard that could load directly into the winbond Bios chip downloaded from the Asus website can't be loaded onto the chip and I can't get it through the usb because the board won't be rolling at all .... Thank you very much everyone for your help
Asus B760M-A WIFI d4 bios
PRIME B760M-A WIFI D4Good evening to everyone I'd like to ask you too much if you don't have a bios into the asus B760M-A Wifi d4 motherboard that could load directly into the winbond Bios chip downloaded from the Asus website can't be loaded onto the chip and I can't get it through the usb because the board won't be rolling at all .... Thank you very much everyone for your help
Write bios with programmer, cheapest model is CH341A.
https://www.youtube.com/results?sear...mer+how+to+useAttached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donate -
Hello After loading bios to chip the base board started working and uz works well🤗 , chip I had to solder and put it in the adapter right on the board it couldn't load ...but it's all right now and the board is starring !!😁 thank you so much and how can I reward myself?Comment
by grimacelordHello,
Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...-
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by piratiHello everyone,
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
- Loading...
