Dell Optiplex 7480 AIO Bios Password Removal Help
  • lamtran20
    • Aug 2021
    • 7
    Serial Number: BBTSQ53
    Dell Optiplex 7480 AIO. It is bios locked, any help removing the password would be greatly appreciated.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12281
    Password removed
    • lamtran20
      • Aug 2021
      • 7
      Thank you. The first bios file is not working. Can you please help unlock this one?
      • lamtran20
        • Aug 2021
        • 7
        I flashed your bios then reflash the one I posted in 1. It won't power on anymore. So I think the bad files was not read correctly. I posted a new one, please help.
          • 21692
          Is that for the same PC at post 1, with the same service tag or another PC with a different service tag. What model/service tag ?
          • lamtran20
            • Aug 2021
            • 7
            No, sorry new here. OptiPlex 7480 and Serial Number: 0DXX2T. It is the same model
            • hoaca388
              Badcaps
              • Jan 2022
              • 12281
              Dell service tag number is 7 digits.
                • 21692
                Service tag is BBPKQ53
                • lamtran20
                  • Aug 2021
                  • 7
                  Here it is BBPKQ53. Sorry I posted the part number before.
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12281
                    Here
                    • lamtran20
                      • Aug 2021
                      • 7
                      Thank you, it worked perfectly.
                      • lamtran20
                        • Aug 2021
                        • 7
                        How would one make a small donation? I gratefully thank you for helping me getting out a a jam.
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12281
                          Welcom. https://www.badcaps.net/donate/
                          • cravel
                            • Nov 2022
                            • 31
                            • philippines
                            hello good day to everyone
                            please help me fix this bios no display
                            OptiPlex 7480 All-In-One ipcml-gz uma
                            Rev A00
                            SN:GHKJX53
                            • danito
                              • Jun 2016
                              • 1076
                              • Romania
                              Rev A00
                              SN:GHKJX53
                              try
                              • cravel
                                • Nov 2022
                                • 31
                                • philippines
                                Originally posted by danito
                                try
                                thankyou very much your file works great
                                • liu573
                                  • Jan 2022
                                  Any one can help me on this
                                  Dell 7480 6FF1 Passowrd
                                  2PL0RN2-6FF1, bios.org wont help f3CK5DxwxCbBVfZU
                                  I guess need master password
                                  • vvulture
                                    • Apr 2015
                                    • 17
                                    I have the same problem. Repaired 7480 found in e-waste bin. Replaced broken LCD screen, but BIOS is locked. Where on the PCB is the BIOS chip located ?
                                    EDIT **** Never mind. Found it. Where can i find indtructions on removing the password ?
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12281
                                      3.4. Dell
                                      Dell laptops store the password in EC. However, some generators exist depending on the code suffix.
                                      See: https://beta.bios-pw.org/ .If the website is offline try: https://web.archive.org/web/*/https://bios-pw.org/
                                      Note: All passwords must be entered with a US QWERTY Keyboard,you can use a USB one.
                                      Note: The 6FF1 suffix has a bug,use your service tag with the 1F5A or BF97 suffix instead,Example: 1234ABC-BF97 .
                                      Note: The list of examples does not include some other suffix codes that do work,such as E7A8 .
                                      Note: If the BF97 suffix does not work try it with the E7A8 suffix instead.
                                      Note: There is no publicly available 8FC8 generator available at the moment.
                                      The CTRL-ENTER-ENTER keystroke after the password only applied to laptops with a suffix (xxxxxxx-8FC8 for example), until Dell also required it in some laptops using System Disable 16-Hex algorithm, on which only the Password+ENTER was needed at first and then in some models you needed the CTRL-ENTER-ENTER to properly delete the system passwords, otherwise the password would remain SET upon the automatic system reboot if just doing Password+ENTER until the proper CTRL-ENTER-ENTER keystroke was performed in certain models.
                                      8FC8 Patcher software: https://www.badcaps.net/forum/troubl...l-8fc8-patcher
                                      • mrrubik
                                        Dell Optiplex 7010 micro bad BIOS flash?
                                        by mrrubik
                                        Hi folks,
                                        I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                                        After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                                        Steps I took:
                                        1. Read BIOS with CH341a, verified hash twice
                                        2. Patched
                                        12-23-2024, 04:11 PM
                                      • zenius
                                        by zenius
                                        12-08-2024, 06:13 AM
                                      • mikeybass
                                        by mikeybass
                                        04-23-2025, 04:30 PM
                                      • Akhlz001
                                        by Akhlz001
                                        09-20-2025, 07:15 PM
                                      • lucaszmn
                                        by lucaszmn
                                        Problem:
                                        Initial Findings:
                                        • I concluded that the
                                        08-12-2025, 03:01 PM
