Dell Optiplex 7480 AIO Bios Password Removal Help
  • lamtran20
    • Aug 2021
    • 7
    Serial Number: BBTSQ53
    Dell Optiplex 7480 AIO. It is bios locked, any help removing the password would be greatly appreciated.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12333
    Password removed
    • lamtran20
      • Aug 2021
      • 7
      Thank you. The first bios file is not working. Can you please help unlock this one?
      • lamtran20
        • Aug 2021
        • 7
        I flashed your bios then reflash the one I posted in 1. It won't power on anymore. So I think the bad files was not read correctly. I posted a new one, please help.
          • 21948
          Is that for the same PC at post 1, with the same service tag or another PC with a different service tag. What model/service tag ?
          • lamtran20
            • Aug 2021
            • 7
            No, sorry new here. OptiPlex 7480 and Serial Number: 0DXX2T. It is the same model
            • hoaca388
              Badcaps
              • Jan 2022
              • 12333
              Dell service tag number is 7 digits.
                • 21948
                Service tag is BBPKQ53
                • lamtran20
                  • Aug 2021
                  • 7
                  Here it is BBPKQ53. Sorry I posted the part number before.
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12333
                    Here
                    • lamtran20
                      • Aug 2021
                      • 7
                      Thank you, it worked perfectly.
                      • lamtran20
                        • Aug 2021
                        • 7
                        How would one make a small donation? I gratefully thank you for helping me getting out a a jam.
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12333
                          Welcom. https://www.badcaps.net/donate/
                          • cravel
                            • Nov 2022
                            • 31
                            • philippines
                            hello good day to everyone
                            please help me fix this bios no display
                            OptiPlex 7480 All-In-One ipcml-gz uma
                            Rev A00
                            SN:GHKJX53
                            • danito
                              • Jun 2016
                              • 1098
                              Rev A00
                              SN:GHKJX53
                              try
                              • cravel
                                • Nov 2022
                                • 31
                                • philippines
                                Originally posted by danito
                                try
                                thankyou very much your file works great
                                • liu573
                                  • Jan 2022
                                  Any one can help me on this
                                  Dell 7480 6FF1 Passowrd
                                  2PL0RN2-6FF1, bios.org wont help f3CK5DxwxCbBVfZU
                                  I guess need master password
                                  • vvulture
                                    • Apr 2015
                                    • 17
                                    I have the same problem. Repaired 7480 found in e-waste bin. Replaced broken LCD screen, but BIOS is locked. Where on the PCB is the BIOS chip located ?
                                    EDIT **** Never mind. Found it. Where can i find indtructions on removing the password ?
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12333
                                      3.4. Dell
                                      Dell laptops store the password in EC. However, some generators exist depending on the code suffix.
                                      See: https://beta.bios-pw.org/ .If the website is offline try: https://web.archive.org/web/*/https://bios-pw.org/
                                      Note: All passwords must be entered with a US QWERTY Keyboard,you can use a USB one.
                                      Note: The 6FF1 suffix has a bug,use your service tag with the 1F5A or BF97 suffix instead,Example: 1234ABC-BF97 .
                                      Note: The list of examples does not include some other suffix codes that do work,such as E7A8 .
                                      Note: If the BF97 suffix does not work try it with the E7A8 suffix instead.
                                      Note: There is no publicly available 8FC8 generator available at the moment.
                                      The CTRL-ENTER-ENTER keystroke after the password only applied to laptops with a suffix (xxxxxxx-8FC8 for example), until Dell also required it in some laptops using System Disable 16-Hex algorithm, on which only the Password+ENTER was needed at first and then in some models you needed the CTRL-ENTER-ENTER to properly delete the system passwords, otherwise the password would remain SET upon the automatic system reboot if just doing Password+ENTER until the proper CTRL-ENTER-ENTER keystroke was performed in certain models.
                                      8FC8 Patcher software: https://www.badcaps.net/forum/troubl...l-8fc8-patcher
                                      • mrrubik
                                        Dell Optiplex 7010 micro bad BIOS flash?
                                        by mrrubik
                                        Hi folks,
                                        I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                                        After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                                        Steps I took:
                                        1. Read BIOS with CH341a, verified hash twice
                                        2. Patched
                                        12-23-2024, 04:11 PM
                                      • zenius
                                        by zenius
                                        12-08-2024, 06:13 AM
                                      • mikeybass
                                        by mikeybass
                                        04-23-2025, 04:30 PM
                                      • capoplays
                                        Help with BIOS update on Dell G15 5515 after chip replacement
                                        by capoplays
                                        Hey everyone,
                                        I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                        The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                        When I check the BIOS using the F12 menu Flash...
                                        10-24-2025, 06:53 AM
                                      • Akhlz001
                                        by Akhlz001
                                        09-20-2025, 07:15 PM
