ASUS UEFI bios find MAC Address, UUID and MB/SN
  • Sparklingx
    • Jul 2024
    • 41
    • Bangladesh
    mobo: ASUS H110M-K
    How to find MAC ADDRESS, UUID and MB/SN from previous dump of this mobo's bios?
    I am guessing I need to add those in the new bin file.
    also where can I find those on the physical motherboard(no box)
    Bios dump is added.
  • DynaxSC
    • Apr 2021
    • 457
    • Poland
    Look for a soft called FD44Editor, u can read and and enter these data with it manually. MAC is mandatory, other data not necessarilly.
    • Sparklingx
      • Jul 2024
      • 41
      • Bangladesh
      I tried the software to read the dump file. but I can not find any UUID or mac or any data showing in the software. May be I have to manually add them to make new bin and flash it?
      Picture attached: tried to read old bios dump.
      and bios bin file is attached using external link:*************************
    • Sparklingx
      • Jul 2024
      • 41
      • Bangladesh
      I can not upload/attach bin file to my post!!
        • 20781
        bin files are not supported, put it in a zip or rar
        • Sparklingx
          • Jul 2024
          • 41
          • Bangladesh
          Here is the old bios bin file(dumped using neoprogrammer, can find uuid here) . zipped and uploaded . May be
          now I will have to manually enter uuid from the mobo box?
          • Sparklingx
            • Jul 2024
            • 41
            • Bangladesh
            hi,
            I have an Asus H110M - K (rev 1.02) motherboard got from my friend. problem is someone flashed a stock bios downloaded from asus website. So even I have dumped the flashed bios in it, I can get no info like ME, mac, uuid etc..... After reading countless posts and guides I have learnt that I need them an im novice Hence posting here.
            Here is the dumped bios attached.
            So can anyone give me a proper bios for this motherboard ?
            And photos of the motherboard attached too it has some numbers, dont know what is what .
            Click image for larger version  Name:	image.png Views:	0 Size:	22.1 KB ID:	3460716
            post moved..
            • DynaxSC
              • Apr 2021
              • 457
              • Poland
              If so this means that u have already a stock bios programmed on the board and the data is lost. U can try to program the missing data to a stock image with FD44, the data is usually to be found on stickers on the board or on the motherboard case. However sometimes a board will not work with a stock bios due to some checks in the bios and different Management Engine programmed into the chipset. Try then to load the first stock bios available on asus site, if u see that the board is starting and updating the Management Engine u may have luck. Check if your cpu is supported by the first bios. But unfortunately this not always works as asus not always publishes the real first stock bios on the support site. The real first bios for asus boards is some kind post production bios, which has the capability to bind the bios with the board and load the Management Engine into the chipset. This works only for asus.
              • DynaxSC
                • Apr 2021
                • 457
                • Poland
                If you can boot the board you can use also a program called DMI Edit Insyde:
                https://download.schenker-tech.de/pa...it-efi-insyde/
                It works directly on the board BIOS, and you can alter all DMI data dynamically. There is a GUI version with limited functionality, but you can use it best by command line directives and batch procedures to backup/view/alter any DMI data. For dumping and programming the bios under Windows you can used also an Intel tool called FPTW64.exe, it's part of the Intel CSME System Tools. You can download it here:
                https://www.station-drivers.com/inde...es/lang,en-gb/
                or here:
                https://xeon-e5450.ru/soft/intel-me-system-tools/
                You must use a specific FPTW64.exe version for the given chipset generation.
                Note that FPTW64 when writing bios to chip does not make an bios upgrade, but it overwrites the existing bios.
                With the CSME Tools you can do a lot more, but this is not an easy to use software.
                FPTW64 is much easier to use than CH341 and it's reliable, as far as you can boot the board to windows. And it works for all vendors of mobo's.
                • Vesko356
                  by Vesko356
                  08-11-2023, 03:27 AM
                • grimacelord
                  by grimacelord
                  07-10-2025, 02:52 PM
                • throwaway327
                  by throwaway327
                  Model No: RC72LA
                  Serial No: SBNVKD001014459
                  06-18-2025, 05:52 PM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
                • grimacelord
                  Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                  by grimacelord
                  This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                  Motherboard model number: DA0PAMB46A1 REV: A
                  Secondary motherboard model number: 0PAB
                  SKU: 685K4UA
                  Serial number is: 5CD3223BJP
                  Recently reflashed this laptop with latest BIOS and once...
                  05-07-2024, 08:06 AM
