ASUS H110-M/M32CD BIOS Request
  • mferna14
    • Jun 2018
    • 1024
    Hi Friends, I am working on an ASUS Desktop M32CD (Model: M32CD-BH72-CB Serial # GAPDCG001138​ , Motherboard P/n H110-1M32CD4/DP_MB Rev: 1.04). The problem was with the BIOS (NO DISPLAY). Got the CAP file from the ASUS website. I had to edit the BIOS as it was larger than the Original & copied from the header (1000000) to create a new file with the extension .bin. I then got the display but it not detecting any kind of HDD or SSD. Tried various HDD with OS too but still the same. I think I did not do a good job in trimming -. Kindly if someone can help & making this working so that it can detect any HDD. I am uploaded the ORIGINAL Bin, CAPS file from the ASUS website & the one which I say 100% working (HDD not detecting). Thanks in advance
  • rex98
    • Feb 2023
    • 1278
    • Mandaue CEBU, Philippines
    this is from my working motherboard. i also put your original DMI in it and clean the me region.
    • mferna14
      • Jun 2018
      • 1024
      rex98., thank you very much for the file. Copied it to the chip & ALL WORKED FINE... Once again have yourself a blessed day.
      • shutt1e
        • Nov 2015
        • 15
        • italy
        Can someone please post a fixed bios because the one posted by rex86 is no more available? tia
          • 20952
          Update BIOS version: 1102 ( For Skylake platform, DDR4 MB )
          Version 1102
          2018/07/23
          Model: M32CD / K20CD / K31CD
          16MB bios
            • 20952
            Update BIOS version: 0602 (for DDR3 MB)
            Version 0602
            2015/12/11
            16MB bios
              • 20952
              Update BIOS version: 0804 (For Kabylake)
              Version 0804
              2018/05/03
              8MB bios
              • shutt1e
                • Nov 2015
                • 15
                • italy
                thanks! 1102 one did the job on mine
                • razor_amd
                  by razor_amd
                  12-15-2020, 07:07 PM
                • grimacelord
                  by grimacelord
                  07-10-2025, 02:52 PM
                • throwaway327
                  by throwaway327
                  Model No: RC72LA
                  Serial No: SBNVKD001014459
                  06-18-2025, 05:52 PM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
                • lrouw84
                  Asus vivobook s510ua bios changed to x510un
                  by lrouw84
                  Hi there,
                  I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                  I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                  01-28-2023, 01:31 PM
