hello can you fix this bios
hp z4 g4 bios
Tags: None
Hi, please help me rebuild bios and clean_ME, ME_Analyzer gives a lot of errors, I did try to clean ME with FIT v.11 but also can't open file. The unit starts but it has no image, no error beeps, nothing. I did check video card and RAM modules, power source, disconnected other peripherals. My guess is bios fcked up.
Serial Number : CZC90886Z7
Product Number : 4BP31UP
Description : HP Z4 G4 Workstation
Motherboard: Z4 G4 Basin Falls AS# 844783-001
CPU: Intel Xeon W-2133
Thank you.Attached FilesLast edited by volinakis; 02-05-2024, 09:26 AM.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Thank you.Attached FilesComment
Hello The unit starts but there is no picture, no error beeps, nothing. I checked the video card and RAM modules, power supply, it was gone while updating the Bios.
Seri Numarası: CZC8198L11Ürün Numarası: 1JP11AVAçıklama: HP Z4 G4 İş İstasyonuAnakart: Z4 G4 PCB REV.1.0İşlemci: Intel XeonAttached FilesComment
Hello The unit starts but there is no picture, no error beeps, nothing. I checked the video card and RAM modules, power supply, it was gone while updating the Bios.Seri Numarası: CZC8198L11Ürün Numarası: 1JP11AVAçıklama: HP Z4 G4 İş İstasyonuAnakart: Z4 G4 PCB REV.1.0İşlemci: Intel Xeon
Any donations to Badcaps are welcome. Become a Badcaps supporter >>>>> click this link to donate <<<<< Thank you to all the supporters. -- -------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
hello, I but a HP Z4 G4 with a password Stringnent , have you a solution to clear password ?
best
brunoComment
by mitchwJust had a customer bring in a HP 14s-fq1010nm to do some maintenance.
After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...-
Channel: BIOS Requests ONLY!
So I couldn't remember my bios password and since it was broken screen, I used to connected to the TV via Type C to HDMI. So I decided to remove the Bios chip and reprogram the Bios chip with ch314a.. when I try to solder Bios on the laptop, one of the Bios leg broke off.. I bought a new blank Bios chip so I can programmed by flashing on the bios.2 Photos
by TechnodocAsus laptop G614JZ-N3012W Rog Strix with i7
Mainboard G634J-PMV-VGT
6050A3441302-MB-A01
2023-02-10
Power button works okay....power light goes on
Red "bottom" leds go on
Charging led works
Fans do not spin, capslock key does nothing, screen stays black
I would like to program the bios again, to rule out a corrupted bios.
However I run into a size error
The bios chip is a Winbond 25R256JVEN
Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...-
by ktmmotocrossHello.
Have this old hp compaq nc6320 that came with one long and one short beep + backlight on. bios battery have only 0.5V. I remove it, but now it start beep some weird way. I think it is bios /one long + two short beeps+ baklight on/, but when i flash new bios from hp, no beeps and no backlight.
i attach record of beeps...04-27-2025, 12:48 AM -
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
