hp z4 g4 bios
tryAttached Filesif you find these attachements useful please consider making a small donation to the site
Hello guys i read this bios both 32mb 16mb on my hp z4 g4 with xeon w-2195 quadro p4000 workin 100% tested twiceAttached Filesif you find these attachements useful please consider making a small donation to the site
I'm currently working on an HP Z4 G4 Workstation and I’m in need of the 16MB BIOS file for this system. The motherboard is labeled:
👉 AS# L09990-001
Unfortunately, the system isn’t booting properly, and I suspect a corrupt BIOS. I’m planning to flash it manually using a CH341A programmer, so I’m specifically looking for the full 16MB SPI dump for the chip MX25L12873F.
If anyone has a working Z4 G4 and could share a dump (or knows where to find an official or clean version), I’d be super grateful!
Thanks in advance 🙏
– CCF
Make good verified backups , post them along with the PC serial number.Hi everyone,
👉 AS# L09990-001
Thanks in advance 🙏
– CCFComment
Every donation made will go towards server fees and maintenance costs.Comment
Type the PC serial number, full name and model, motherboard model, etc.
post the contents of the bios chip even if it is corrupted..
read the forum rules..https://www.badcaps.net/forum/troubl...before-postingComment
HI-- BIOS LEED RED 3 FROM RAM
PLESE HELP ME
serial number.MXL9143CNR
PRODUCT NO. 3WE02UT#ABA
Z4G4/CORE 177800XAttached Filesif you find these attachements useful please consider making a small donation to the site
HP Z4 G4 Workstation Core-X WKS
https://www.badcaps.net/donateComment
Thank you very much for your service..but the file does not work. Three beeps with two beeps with a red light. I am sure that my RAM is working.
Serial: MXL9202RV2Attached Filesif you find these attachements useful please consider making a small donation to the site
Hello brothers, I have a group of z4g4 devices, both Xeon and Core, with the same problems. All Xeon devices had problems that were solved by charging the BIOS for the two 16+32 SIM cards, but the Core devices did not have their problems solved. They do not sense the graphics card at all and stop at the graphics card code and do not give a graphics card warning. Everything was changed and the same problem remains. I think that the BIOS file is missing a file for the graphics card??Attached Filesif you find these attachements useful please consider making a small donation to the site
I am not a computer repair specialist so I cannot answer you.
Hello brothers, I have a group of z4g4 devices, both Xeon and Core, with the same problems. All Xeon devices had problems that were solved by charging the BIOS for the two 16+32 SIM cards, but the Core devices did not have their problems solved. They do not sense the graphics card at all and stop at the graphics card code and do not give a graphics card warning. Everything was changed and the same problem remains. I think that the BIOS file is missing a file for the graphics card??↵
hello .. bios z4g4 workstation XEON
no data
no beeb
serial no.mxl9262jbv
product no.3KX06UT#ABAAttached Filesif you find these attachements useful please consider making a small donation to the site
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
Channel: BIOS Requests ONLY!
by mitchwJust had a customer bring in a HP 14s-fq1010nm to do some maintenance.
After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...-
So I couldn't remember my bios password and since it was broken screen, I used to connected to the TV via Type C to HDMI. So I decided to remove the Bios chip and reprogram the Bios chip with ch314a.. when I try to solder Bios on the laptop, one of the Bios leg broke off.. I bought a new blank Bios chip so I can programmed by flashing on the bios.2 Photos
by TechnodocAsus laptop G614JZ-N3012W Rog Strix with i7
Mainboard G634J-PMV-VGT
6050A3441302-MB-A01
2023-02-10
Power button works okay....power light goes on
Red "bottom" leds go on
Charging led works
Fans do not spin, capslock key does nothing, screen stays black
I would like to program the bios again, to rule out a corrupted bios.
However I run into a size error
The bios chip is a Winbond 25R256JVEN
Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...-
Product ID: RZ09-0421
Motherboard: CH580
Bios File Size: 32,768 KB
Dear Forum Readers!
!!! MY RAZER BLADE...-
11-24-2025, 05:52 PM -
- Loading...
