Dell Wyse 5070 BIOS update not possible
  • noTurner
    • Nov 2022
    • 61
    • Austria
    Hi there! As stated in the title of the thread, one of our problematic Dell Wyse 5070 does not update its BIOS. Is anyone here able to help me by cleaning the BIOS regions and possibly updating the BIOS to ver. 1.20.0?
    The service tag is FMWF5P2.
    I got a dump of its original BIOS with version 1.1.3.
    Thanks!
  • noTurner
    • Nov 2022
    • 61
    • Austria
    Re: Dell Wyse 5070 BIOS update not possible
    @hardware1 You were a great help last time, may I know if you are ready to help me out again? I know, it's really weird that these Dell ThinClients have interesting issues. I did post the original dump this time.
    Thanks!
    • hardware1
      • Sep 2021
      • 2936
      • N/A
      Thanks!
      Here's your New BIOS, try it and let me know the results.
      all donations are welcome,
      • noTurner
        • Nov 2022
        • 61
        • Austria
        Thank you so much, gonna try it right now!
        • noTurner
          • Nov 2022
          • 61
          • Austria
          Unfortunately, the power LED blinks now. 2 blink pause 1 blink.
          + 4 blink pause 1 blink = CPU config issue or CPU issue
          • hardware1
            • Sep 2021
            • 2936
            • N/A
            So it's the same symptoms as before or it's different?
            Have you tried to use another CPU? Because you said that the blinking code is pointing to a CPU issue.
            • noTurner
              • Nov 2022
              • 61
              • Austria
              No no, the machine works with the dump I have posted. There's no CPU issue. It happened after flashing the BIOS you provided.
              • noTurner
                • Nov 2022
                • 61
                • Austria
                Flashed 1.1.3 old BIOS again, machine starts and boots normally, but I can't update its BIOS..
                • hardware1
                  • Sep 2021
                  • 2936
                  • N/A
                  Why you can't update the BIOS? Is there something preventing you from updating?
                  • noTurner
                    • Nov 2022
                    • 61
                    • Austria
                    It's preparing the update, but then restarts and boots directly into the system without updating.
                    • noTurner
                      • Nov 2022
                      • 61
                      • Austria
                      I guess that there's no way to fix that 😅
                      • noTurner
                        • Nov 2022
                        • 61
                        • Austria
                        I guess that the ME firmware needs to be cleaned or reinitialized.
                        • noTurner
                          • Nov 2022
                          • 61
                          • Austria
                          Problem solved after cleaning ME region. Updated BIOS without any issues, all fine right now. Thanks to everyone who tried to help! Thank you too, hardware1.
                          • hardware1
                            • Sep 2021
                            • 2936
                            • N/A
                            You're Welcome.
                            Can you describe more how you cleaned the ME Region? Because this device doesn't contain ME Region! It's a TXE Region and I have already cleaned it before give it to you.
                            • noTurner
                              • Nov 2022
                              • 61
                              • Austria
                              You're Welcome.
                              Yeah sorry, it's TXE (CSTXE). I cleaned it by using the dump as base file. Then I replaced the TXE FW with 4.0.x.1235_B (don't know the exact name), flashed the new image, booted just fine with old 1.1.3 BIOS, then I simply used F12 menu to update BIOS from USB but before that I did make sure that the TXE was initialized using fptw64 -greset. I updated to 1.7.0 BIOS without any issues and then went for the latest BIOS. Machine works perfectly fine. Saved 28 ThinClients from our company. They had all the same issue, as users of the ThinClients turned off the machine while it was updating BIOS, (most likely when it was updating TXE region?) which then resulted in dead machines. All machines work perfectly fine now and I did it in less than an hour xD
                              • hardware1
                                • Sep 2021
                                • 2936
                                • N/A
                                Great job.
                                • noTurner
                                  • Nov 2022
                                  • 61
                                  • Austria
                                  Great job.
                                  Thanks! 😊
                                  • Stunt
                                    • Oct 2019
                                    • 182
                                    • South Africa
                                    Hi can anyone help me remove bios password on this Dell Wyse 5070
                                    Service Tag 1RBVGT2
                                    • Stunt
                                      • Oct 2019
                                      • 182
                                      • South Africa
                                      Service Tag 1RBVGT2
                                      Hi guys anyone who can help me remove this password please
                                      • noTurner
                                        • Nov 2022
                                        • 61
                                        • Austria
                                        Hey, you just need to put the jumper on the board to CMOS CLR and leave PW CLR free. Then remove the jumper from CMOS CLR and boot the thin client. (Without putting the jumper on any of the pins)
                                        It'll then switch to manufacture mode and delete the supervisor password.
                                        • mikeybass
                                          by mikeybass
                                          04-23-2025, 04:30 PM
                                        • trix11
                                          Dell Precision T1650 MT Workstation bricked after BIOS update
                                          by trix11
                                          I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
                                          - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
                                          - Dell Precision T1650 mid tower Workstation
                                          - Xeon E3-1225 V2
                                          - 32Gb PC3-12800E RAM
                                          - 4Tb SATA HDD
                                          - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
                                          I see now that others have experienced like issues e.g.:
                                          - https://www.dell.com/community/Prec...
                                          10-24-2022, 10:35 PM
                                        • lalle-
                                          Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
                                          by lalle-
                                          Hello!
                                          I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
                                          [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
                                          I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
                                          The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
                                          I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
                                          08-11-2024, 02:01 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • nikal
                                          DELL Wyse 5070 BIOS
                                          by nikal
                                          Hi!
                                          I kindly need your help with a DELL Wyse 5070 thin client which has locked BIOS settings (I want to change the boot order but I have to provide a password first). Is it possible for someone here to help me ?
                                          I am attaching the original bios dump of the machine in question.
                                          Service Tag: 5X1ZQL3
                                          I would really appreciate any help.
                                          Thanks in advance!​...
                                          10-04-2024, 02:22 AM
