SX280 full poly
  • PCTechNY23
    • Oct 2009
    • 26
    SX280 full poly
    Is it safe to use a 330uF poly to replace the 1500uF lytic? I have seen a lot of people using 1/2 but less than 1/4 seems like it might be a problem.
    The 3x 330uF 16v Polymers replace the 1500uF 16v Lytics
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: SX280 full poly
    Thats more like 1/5 the total capacitance. You can try anything for kicks, but I'd advise not to.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      Re: SX280 full poly
      Works fine, I've already tried it.
      https://www.badcaps.net/forum/showthread.php?t=9504
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • Scenic
        o.O
        • Sep 2007
        • 2642
        Re: SX280 full poly
        i guess those are the 12V input caps..?
        if so, i haven't seen any newer boards that came with poly's from the factory with anything higher than 4x 470uF 16V in there. most use 330uF caps for 12V VRM in..
        • Pyr0Beast
          • Feb 2009
          • 406
          Re: SX280 full poly
          I'd advise against it unless terribly needed. Bulk capacitance IS needed.
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16958
            Re: SX280 full poly
            Incorrect. All the test subjects are rock solid with these (2x SX280's and 2x GX620 USFF), going on 6 months now of running 24/7 @ 100% CPU load crunching F@H. Never had one crash or become unstable. If the bulk capacitance were truly needed, it wouldn't have stood up to a week of this kind of abuse, let alone 6 months.
            FWIW, the 1500uF 16v lytics rarely fail on these unless they're nichicon or UCC. Never seen these 3 caps fail if they were rubycon or panasonic.....so if that's what you have, you don't have to change them.
            Team : 49813
            Join in!!
            Team Stats
            • larrymoencurly
              • Oct 2004
              • 960
              Re: SX280 full poly
              Or the mobos were built with a lot of margin?
              How much can the capacitance be decreased? It seems that most factory installed polys are about half the capacitance of conventional electrolytics that would go in the same place, but 330uF is only a fourth. Is that still OK?
              • Pyr0Beast
                • Feb 2009
                • 406
                Re: SX280 full poly
                What about undershot or overshot events ? Have you even put a scope to check it out ?
                Yes, I know it works, how well and for how long is the real question.
                I've recapped a mobo from 1500uF taepos to 1000uF Nichicon UHD solid caps.
                Esr is less that 1 tenth of the original value. But system did crash, and mouse worked sporadically.
                Once I attached 3 2200uF panny's at the bottom it worked flawlessly.
                This is how it looked at load transient. It is horrible.
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16958
                  Re: SX280 full poly
                  [I]Have you even put a scope to check it out ?
                  No scope, just the real world acid test. 6 months and counting of 24/7 F@H, which is a hell of a stress test. It has been rock solid. As for how long, the polymers will outlive the lytics, so that should be for how long. I've also put a few of them into the real world, none have come back or have been reported as unstable, and some of these have been in service close to 2 years. I didn't mention these, as I don't have them in my posession. However, I still receive repair work from this corporation, had they failed or become unstable, they would have returned them. I know their admin quite well, he's personally using one of them.
                  I haven't used my scope in years, it probably doesn't even work anymore (older tektronix). The trusty oscope came in handy for old CRT television troubleshooting and repair. However in the PC field, I've found that in the world of polymodding, trial & error and stress testing utilities were just as accurate (if not more so) of indicators than a scope. I'm certainly not saying you're wrong, but the real-world testing hasn't revealed any problems by using this mod.
                  Team : 49813
                  Join in!!
                  Team Stats
                  • Pyr0Beast
                    • Feb 2009
                    • 406
                    Re: SX280 full poly
                    2 years is a fair trial. It would break much sooner, even in a day or so if something would be horribly wrong.
                    However, I would still advise against it unless absolutely necessary. I have found out in many situations, fiddling with the design can make it worse, much worse, like sticking low esr caps in PSU's. Some live just fine, but some whine horribly about it. Others don't even start.
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      Re: SX280 full poly
                      330@16 sanyo sep in every one i do.
                      and mine come from the worst possible environment.factories and machine shops.
                      scope check shows everything perfectly clean.
                      one of my first 280 poly mods is at a neighbors place.they run seti@home on it and never turn it off.2 years and counting.been rebooted 4 times in 2 years for updates.i have 60 280 boards going out today and that customer has over 200 that i polymodded.the mod is well proven.
                      • CapLeaker
                        Poly VVX-250 VOIP POE problem not booting fix
                        by CapLeaker
                        I've got a bunch of Poly VVX-250 VOIP phones that work fine as kind as long as they are plugged into the wall wart. Recently I got around to install a couple of TP-Link 5 port POE switches that are added to the existing plain Jane 24 port unmanaged switch. Great!!! Finally I am able to ditch the wall warts from these phones making more space on the desk, plus I am gaining some badly needed power outlets. So I thought.
                        Plugged in the first VVX-250 into the POE switch, booted up no problem. Plugged in the other Poly phones and they start to boot anywhere from 5 to 15 seconds,...
                        11-25-2023, 10:46 AM
                      • dhan
                        HELP: 330uF tantalum capacitors
                        by dhan
                        Hello Everyone,
                        I'm just a bit curious or let say uncertain for these caps.
                        I have tried to replace NEC tokin 0E907 with 4 pcs of 330uF 2.5V.
                        the laptop works fine.
                        then another laptop (different laptop) came after a year, with the same issue.
                        but this time I have a different type of 330uF tantalum caps.
                        the one I've used before was 330 with small letter e on the markings.
                        e = 2.5V, but this time I have 330uF with letter d on the markings
                        d= 2.0V, right? correct me please.
                        the question is, does 4 x...
                        11-15-2020, 01:31 AM
                      • jpreza
                        Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                        by jpreza
                        I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                        Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                        It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                        Looking at the card, it appears to be missing the following:
                        1x 1.0uH inductor - orange square
                        2x...
                        11-01-2024, 10:54 PM
                      • xnRS
                        3300uf 6.3V Poly recpaing
                        by xnRS
                        I got an old AM2 board with 3300uf 6.3v badcaps(all). So I want to change them with poly ones. Can you give me advice which capacity should I use ? I saw on one russian forum(rom.by) that capacity of poly should be around third of current leaky caps, but I'm not sure.
                        07-09-2021, 03:45 PM
                      • Rotsinger
                        I replaced one Xbox 360 16v 1500uF Cap with 25v 2200uF what issues will it cause?
                        by Rotsinger
                        So the 16v 1500uF capacitor C9B1 near the power connector on the back of a Phat started leaking. Haven't been able to find the right cap, so I replaced it with a larger 25v 2200uF capacitor a couple weeks ago and everything is working fine since then. I didn't replace the other six 16v caps, they were all good.
                        When putting the fan plastic cover back I remember there were maybe 2-3 mm of clearance on top of it and 1-2 mm of clearance to the side of it.
                        For those that don't remember what the fan cover looks like I found this picture https://cdn.quade.co/wp-content/uploads/2...
                        08-10-2021, 11:07 AM
