Its about time epox!!!!!
  • Rob
    • Oct 2005
    • 47
    I opened my Epox board expeccted to see GSC and Hermei caps all over the board... Its even the cheaper model the EP-9HEAI kt890 and it has all rubycon and sanyo caps!!. I think epox may have learned their lesson and went with quality caps.
    Eh... I see 2 small teapos...
    still not bad
    -rob
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Its about time epox!!!!!
    pic would be nice
    but anyway
    enjoy your chips
    it is indeed hoped that epox have learnt their lesson, maybe we can see an end to burnt atx connector also.
    • Rob
      • Oct 2005
      • 47
      I can get some pics. My HP camera is pretty blurry so ill have to get out the a510 to take the pics.
      I was shocked to see them myself. BIG improvement.
      Ive actually been hanging around the forums for a couple months now... Since I got this board I thought it would be worth posting.
      rob
      • gg1978
        • Dec 2004
        • 431
        I've been avoiding Epox for just that reason, with the GSC and other crap caps i've seen on them.. I've got 3 or 4 Epox boards from 2002 to early 2004 vintage, all with bad caps.. Although the latest one has Sanyo caps in the VRM section, and crap everywhere else.. I guess i might try buying an Epox board now..
        • Rob
          • Oct 2005
          • 47
          http://forums.pcper.com/showthread.php?t=404682 scroll down and theres a pic of someones 9NDA3J. As you see rubycon and sanyos also!
          One teapo.
          • Fatal0E
            • Jan 2004
            • 252
            looked at some pics of it, looks like all the 1000uf are OST
            • AK0R
              • Mar 2005
              • 204
              Are you going to re-cap them yourself, or would you like them re-capped?
              • gg1978
                • Dec 2004
                • 431
                I'll eventually get around to doing them.. I've done more than a few cap replacements, so it's no big deal for me.. They all still work, but i've taken them out of service.. They'll probably hang out in my desk drawer until i need a replacement Socket A board, then i'll recap them.. Two of them are KT266A, one's a KT400, the other is a Nforce2.. I think i have an 8k7a that was "factory recapped" with all teapo's.. So make that 5 Epox boards i have that have at least some crap caps on them..
                • Rob
                  • Oct 2005
                  • 47
                  this is the best pic i got.
                  • arneson
                    • Sep 2005
                    • 1267
                    I see a problem here, The topleft corner of the board is rubbed out.
                    Jim
                    • titomno2
                      Gaming Laptop Zephyrus S17 TFT not detected every time !
                      by titomno2
                      Hi guys,
                      I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
                      So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
                      On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
                      Then the screen won't work for a long period of time.
                      If I wait 1 or 2 hours it work again most of the time.
                      When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated...
                      01-19-2025, 08:27 AM
                    • flat-earther
                      Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
                      by flat-earther
                      I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
                      To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
                      I have opened the camera and I think there is enough room to add something inside to accomplish this:
                      The camera is powered by a 3.7V nominal single cell lithium ion battery.
                      So I need to connect another battery in...
                      06-08-2025, 02:00 AM
                    • OscarAV
                      HP Pavilion dm4-1065dx long time to get the power led on
                      by OscarAV
                      I just came here to see if someone has had the same problem I have, and if he or she solved It, to know how to do It.
                      I have made a quick search for my laptop but I have not seen anything similar.
                      I have an old laptop, an HP Pavilion dm4-1065dx which takes a lot of time to be ready to start if the laptop has been unplugged for a while. It has no battery. The battery failed long time ago. It needs to be plugged to work. But as I said, It can take a lot of time until the charging led gets on, and I can switch on the laptop. I am using an external monitor...
                      09-23-2024, 05:53 PM
                    • BigOof
                      Pioneer RM-07 Active monitors cutting out from time to time
                      by BigOof
                      I have a pair of Pioneer RM-07 monitors that I bought a while ago. When I was testing them I noticed that one speaker would cut out and I thought it was just a bad cable connection. At the price they were being sold for I was willing to take a risk on them. However, 6 months later and the one monitor still has the same issue. Most of the time it works, but there are times that the power LED is on but I get absolutely no sound. I can hear the relay clicking on/off sometimes and then it will/won't work depending on what it feels like. I've tried XLR and RCA inputs with the same issue. There's no...
                      12-18-2024, 04:35 AM
                    • nieljosiah
                      HP Notebook - 15-ba017ax (LA-D711P Motherboard) turns off randomly after some time
                      by nieljosiah
                      I've had this laptop for 8-9 years, and about a week back, it started malfunctioning. When I press the power button, the power LED comes on for about 5secs and turns off. The fan also doesn't spin at all during this time. But, if I press the power button, and then manually spin the fan, the laptop boots up and the fan starts spinning on its own. Even if I do this, and the laptop boots up, it turns off (hard shutdown) after some time between 10secs and 1hour randomly. I've tried checking the fan voltage and it's at zero volts when I press the power button without spinning it, but when I spin the...
                      08-17-2024, 02:19 AM
