HP 752n imperial mobo bad 1500uf 6.3v 105c tms
  • Jertech
    • Jun 2010
    Hello, New to yopur forum. First Mobo recap. replaced caps in other items LCDs, PSUs etc. Feel kinda stupid after alot of searching still need advice on replacement. They're 8mm x 20mm I have a link to same looking placement and condition
    http://img406.*************/img406/4...tmscapsqx0.jpg
    will post pic if you need. Seems like the rubicon
    https://www.badcaps.net/store/produc...products_id=40
    would work except for size issue pretty tight don't really want tothem touchng do you. These
    https://www.badcaps.net/store/produc...products_id=66
    are right size don't know seiries or quality info. Doing this gratus for a neighbor I replaced the PSU 2yrs ago, was the perverbial Bes/worstec 250!
    He's a nube to computing and doesn't use much, but we are in Phoenix, AZ (current temp 108f)so need the best performers, Temp wise. He uses AC only during monsoon season otherwise swamp cooler or if it goes above 100f try to get hime to lower the thermostat but he says he likes the heat?
    So please advise!
    Appreciate any notes to make job easier.
    Have temp controlled iron,
    2 guns Weller 250w and 150w?, and vacume type solder sucker.
    Still using LEAD solder...... OK?
    Thanks in advance look forward to replys
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: HP 752n imperial mobo bad 1500uf 6.3v 105c tms
    leaded solder is ok. actually better than the RoHS leadfree BS, because it's much easier to solder with.
    this one here
    https://www.badcaps.net/store/produc...products_id=39
    would be a good substitute. size is the same. going up voltage wise doesn't usually hurt anything.
    those would also work. wouldn't go any higher than that (capacitance wise) though.
    https://www.badcaps.net/store/produc...products_id=36
    as for samxon.. those are also good caps, but i still have a hard time comparing them to other caps (like Rubycon MBZ/MCZ) just from the series marking..
      • 30999
      stop putting a screwdriver on the cooker and buy a decent iron!
      • Scenic
        o.O
        • Sep 2007
        • 2642
        80W temp. reg Weller soldering station (heavily (ab)used)
        35W Ersa soldering iron (nothing fancy)
        leadfree solder is still a PITA.. not even talking about the tin whiskers.. >.>
          • 30999
          wiskers = wrong/no flux.
          usually caused by too much heat.
          i run at 370'
          • c_hegge
            • Sep 2009
            • 5219
            Samxon GC = MCZ. Go with the 8mm GCs or the 10v MCZ caps. Replacing a 6.3v cap with a 10V never causes problems.
            • ChaosLegionnaire
              by ChaosLegionnaire
              09-13-2022, 09:02 AM
            • tmcw
              Drying Oven - Preset Temp Fail
              by tmcw
              Here's an unusual one...
              This is a Gallenkamp oven, used in a laboratory space, goes up to 220 Celcius, but is usually maintained at about 115 Celcius. Used for drying glassware, molecular sieves, and so on. Oven is in excess of 20 years old.
              It heats up fine, there is an orange light on the front that indicates that the unit is heating, and when it reaches the preset temp, the orange light goes out. All good so far.
              However, after the preset temp is reached, the temperature continues to rise, power to the heating elements isn't cut off.
              01-21-2021, 03:11 AM
            • foshland
              MSI MAG Z390 Tomahawk BIOS temp, allways at 0ºC and CPU goes protection 800Mhz
              by foshland
              Hi to all, my motherboard (bought second hand as faulty, but now working after cleaning the ram slots) have a strange failure that shows 0 Celsius degrees in BIOS, because of that, the CPU goes to protection mode and gets stuck at 800Mhz.
              Since its a 8-9 Intel generation, I know the CPU temp is the hottest temp of the cores (as i have read in intels documentation) so its not a diode or sensor on the board.
              External temperature (motherboard temp) is working OK, 27ºC more or less
              In windows, all the software I have tested shows correct the Core temps
              12-16-2023, 09:08 PM
            • mosfetratus
              concerning gtx675m vram temp
              by mosfetratus
              Is 98C vram temp are safe? Less demanding games goes 80ish.
              Funny thing, there were old non stock thermal pads very botched, so i replaced them. After, temperatures remained the same, but performance (fps) improved significantly. With both thermal pad application GPU core temp was similar.
              furmark goes about 104C, amperage keeps rising so do temps.
              01-30-2025, 08:41 AM
            • Cerberuska
              Mobo MSI B550-A PRO password popup
              by Cerberuska
              Hello guys,
              I have interesting problem. My MoBo MSI running on Ryzen 7 w/o graphics just good. I swapped to Ryzen 5 5600G and on the boot I stuck with screen on picture. Enter Password. I checked BIOS setting with Ryzen 7, no security is enabled, BIOS password or TPM.
              BIOS I updated to last one.
              any suggestions?
              And same thing for two different 5600G, and yes, MoBo supposed to support it.
              Thank you...
              11-10-2024, 01:23 PM
