How to program IR3567B and similar?
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys
    Does anyone know anything about programming these multiphase VRM controllers? IR3567B
    I have a couple of graphics cards here (RX 480) that seem to have faulty chips but I was told that these are programmable devices and you can't just fit a replacement.
    I found this VRMtool
    https://www.overclock.net/threads/vr...llers.1605757/
    but from what I can see it is no use in this situation as it needs the IR3567B to be working so it can be programmed?
    So I am thinking i need someway to dump the file from a working card (or download one) and then program my replacement chip. Or am I over complicating this - will an off-the-shelf IR3567B just work?
    cheers
    Rich
    Follow me on YouTube
    Learn Electronics Repair
  • R_J
    • Jun 2012
    • 9606
    Re: How to program IR3567B and similar?
    Looks like it needs to be programmed
    Yes indeed. If you want programm new IR3567B you need get somehow dump from same type videocard and then write that dump into new ic. Actualy get dump is easy part, you may use for it MSI Afterburner with key "-i2cdump". But for writting down dump you need programmator with supporting this type of ic. Or you can try to interact with ic over I2C protocol by simple selfmade programmator (most simple programmator consist of 2 resistors).
    Unable to post url
    • bajinchi
      • Jul 2012
      • 14
      • Argentina
      Could be that just when replaced with a new one, when the graphic card is working again, could be programmed after with the OS working and not before?
      And yes, you should get parameters from a working one, or maybe the OC software can program it too trying to OC or Stock the GPU?
      • jocteza1
        • Aug 2021
        • Philippines
        same question from this thread. what kind of tools and equipment use to reprogram of this ic IR3567B?
        • bgrar123
          • Jun 2022
          • 15
          • Poland
          USB005 USB do I2C PowlRCenter
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
          • modtool
            Macbook Pro 14 2021 - A2442 - 820-02098-A - Internal display not turning on but MacOS working good
            by modtool
            Dear collegues,
            the owner of this machine brought it to me saying that suddenly one day the display didn't turn on anymore, he tought that all the machine was damaged but it turned out that the MacOS starts good and stays on, and that connecting it to an external display it works without problems.
            If you take a look into general settings, you can also see that the internal retina display is recognized as connected by the main board but for an unknown reason it doesn't turn it on.
            I've tried to put a bright light towards the screen but I can't see anything, any shadows or apple...
            05-08-2024, 05:50 AM
          • shamsudeen
            Epson M3170 Monochrome inkjet printer adjustment program tool
            by shamsudeen
            Epson M3170 Monochrome inkjet printer adjustment program tool.
            Hi, i want to reset a epson reset program tool needed to reset the EPSON M3170 PRINTER's Maintenance box,
            anyone having it, please share
            Thank you
            07-08-2025, 06:42 AM
          • Nikan.e
            How to program a specific flash region of a Nations N32G455RE MCU?
            by Nikan.e
            Greetings and salutations!
            I have a device that uses an N32G455RE. Unfortunately, its flash got corrupted. I have a dump of a working chip.
            How can I program a specific region of the flash or the whole flash without touching the RAM, option registers, etc.?
            I do not have a J-Link debugger and won't buy one, as I am not rich.
            I have flashed a Nucleo board with an ST-Link to a J-Link just to find out that the ST-J-Link only supports ST chips.
            What would be the cheapest and easiest option to program the Nations chip's flash without touching registers etc.?...
            05-23-2024, 11:51 PM
          • desone01
            Changing Dell Asset Tag
            by desone01
            I have dug through my Dell utilities and located an old Dell Engineer's program which changes the Dell Asset Tag. I have used this SUITE of programs in the past to amend the Asset Tag on second hand motherboards I have installed.
            I don't know if it works with the newer Dell laptops. You should use extreme caution in using these programs. As you can see the program is fairly old one.
            Here are the instructions from the README file:
            SVCTAG.EXE
            Dell Internal Use
            09-04-2020, 07:33 PM
