8RDA recap problems
  • WebCaster
    • Oct 2005
    8RDA recap problems
    I read most of the posts regarding the recapping process. I got a whole load of rubycon ZLs to replace my buldged GSCs. After solderingon the rubies, I booted up the board, the board stopped at C1. Telling me an error at the memory or cpu. Tried two sets of rams and cpu. C1 din go away. Btw I din change all the rubies coz the Teapos din look damaged, plus the rubies that were supposed to replaced it were much too big 12.5mm vs 10mm in a row. Too bad I'm living in Singapore, to send my board for a recap by the pros here. ARGH, really driving me up the wall...
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: 8RDA recap problems
    what was the status of the board before the recap?
    teapos generally never look bad but can be inside. recommended to replace. if you have space problems you can angle some of the caps. looks bad but works fine.
    pm BluBlur from this forum, he is in singapore, maybe can tell you where to find smaller caps.
    check your soldering on the rear of the board for shorts. can also try removing the cmos battery for a while and then trying to boot later.
    • AK0R
      • Mar 2005
      • 204
      Rubycon MBZ are available in 8mm up to 1500uF at 10V, 10mm up to 2200uF at 10V, and 10mm up to 3300uF at 6.3V. Panasonic FC and FM are also good, and readily available.
      • WebCaster
        • Oct 2005
        Thanks for your replies. Yes, the board was working just unstable, randomly crashes. I've replaced the Teapos, I still get a C1 error. Just finished soldering, kinda tired. Now all my caps above >1000uF are rubycon ZLs. I rechecked the board for shorts, but the pins are apart, I don't see any shorts. The CPUs and RAMs worked fine in my other set. I did reset the cmos a couple of times and tooked out the battery while doing the soldering. Thanks again!
        • BluBlur
          • May 2005
          • 45
          The Rubycon MBZs are rare gems in the singapore consumer market. Still finding out where these good stuff are hidden...
          WebCaster, maybe you can post the cap value of the Teapo and I'll try to help.
          • WebCaster
            • Oct 2005
            Thanks for your reply Blublur, I replaced all the capacitors which are 1000uF and above. I took sum wires soldered it to the holes on the motherboard where the 3300uF teapo caps were and wired it to a breadboard n stuck all the 3300uF ZL caps onto the breadboard, to solve the space problem. However, it still gave me a C1 error. I tested the board with a Tbred 1700+ and a stick of Kingston 256MB and swapped it to a Palo 1800+ and a stick of Crucial ECC. Still no go. Maybe I could have damaged the board while soldering. shucks what a first attempt.
            • jean luc ferre
              laptop hp g72 b52sf screen problems
              by jean luc ferre
              on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
              the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
              i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
              i don't understand the reasons of the white stripe at the bottom of the screen below the task...
              06-07-2025, 03:27 PM
            • Hondaman
              USB problems?
              by Hondaman
              Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
              (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
              I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
              08-12-2024, 03:26 PM
              ASUS P5GC-MX motherboard recap
              by momaka
              Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
              This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
              So here is what the motherboard looked like with its original caps:
              CPU VRM area up close…...
              01-27-2021, 11:59 PM
            • clabr
              Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
              by clabr
              Need help to solve some problems with this laptop.
              After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
              After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
              Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
              Before this had happened I observed some other problems:
              When I tried replacing original mecanical HDD with a SSD HDD could not get them...
              12-02-2021, 08:09 AM
            • ohren
              What problems could this blown cap cause in a Marantz SR5400?
              by ohren
              I'm looking at a vented C513 in a Marantz SR5400 (photo included), in the FR section on page 24 in the service manual (https://audiocircuit.dk/downloads/ma...400-avr-sm.pdf).
              R533 right below it in the photo is charred, but measures the correct value.
              1. I'm not familiar with amplifier circuits (at all — don't know the difference between classes, etc.) so I was wondering what problems would manifest from a supposedly non-operational C513? I didn't hear anything odd when testing the output channel with a speaker. Is there a simple test that can be done...
              10-21-2025, 09:02 AM
