Gigabyte Aorus 1080ti - card not initialising
  • mo5t_want3d
    • Oct 2022
    Re: Gigabyte Aorus 1080ti - card not initialising
    Originally posted by benwaterson
    More up to date info regarding testing of these https://youtu.be/IBW5alE6K0w?t=345
    Hi Ben, how did you go with this? Did you manage to find a solution?
    • WhyINeedAccount123
      • Feb 2021
      • 19
      • Poland
      #102
      Originally posted by DynaxSC
      Hi Benwaterson
      Thank you very much for this video, just repaired a MSI GTX Aero Mini ITX thanks to this video. It had also read errors on all ram chips, worked sometimes, but stopped under load. Exchanged the Bios from MX.. to Winbond, and now it's working perfectly !
      Hi i have gtx 1070 with the same problem, can you tell me with windbond chip did you used?
      • myth77
        UV solder mask - high temp resistent, recomendation?
        by myth77
        Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
        Is there any solder mask...
        03-28-2022, 04:04 AM
      • janos666
        Pioneer LX5090 - 2x Red blink after auto-shutdown
        by janos666
        I was trying to reset the Pulse Meter and re-adjust the Panel-1/2 settings in the SM on an exceptionally old Pioneer LX5090 (51k power-on hours according to it's SM). I did this many times on much less aged specimens (with 10-20k hours) without issues. After following the usual workflow, I noticed the darkest gray shade showed up black with bright sparkles. I tried to adjust some other parameters but it didn't disappear. Then I went on and restored the old values of the parameters I don't usually touch (although I did this from memory, so I might have made an error). After that, I started going...
        03-26-2023, 11:20 AM
        NVIDIA GeForce GTX 1080 1080Ti Schematic & Board View
        The GeForce GTX 1080 was a high-end graphics card by NVIDIA, launched on May 27th, 2016. Built on the 16 nm process, and based on the GP104 graphics processor, in its GP104-400-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 1080. The GP104 graphics processor is a large chip with a die area of 314 mm² and 7,200 million transistors. It features 2560 shading units, 160 texture mapping units, and 64 ROPs. NVIDIA has paired 8 GB GDDR5X memory with the GeForce GTX 1080, which...
        10-02-2024, 07:37 AM
      • nubinator
        Tape mask on samsung RU7100
        by nubinator
        I got boot looping 65RU7100 and did tape mask and got image back. I narrowed down the problem to 1 pin it was pin 16 on left side which is CKVB1 so I masked that pin as well as CKV1 cause I read should do them in pairs. Image is pretty good but I get horizontal scan lines on bad side of panel, any way to fix this? When I was experiementing with blocking CKV pins I noticed the more I blocked the more color loss I got on bad side of panel
        05-21-2025, 06:49 AM
      • klugec
        KVA2 RTX 2060 Super 8GB Desktop artifacts
        by klugec
        Hello (sorry for my bad English),
        I have a strange problem with my KVA2 RTX 2060 Super. As soon as Windows 11 is loaded, artifacts appear. Now the crazy thing: When I start Furmark the artifacts are gone and Furmark runs great without crashing. Mats test shows me no errors (PASS). Drivers can also be loaded without any problems.
        Mods shows me the following error:
        Code:
        MODS start: Thu Feb  1 19:16:00 2024
        Command Line : gputest.js -oqa -old_gold -test 94 -dramclk_percent 100 -ignore_fatal_errors -run_on_error -fan_speed 70 -matsinfo
        02-01-2024, 10:58 PM
